SF90 door won't open or close | FerrariChat
Discussion in 'Technical Q&A' started by Gusthavo, Aug 5, 2024.
  1. Gusthavo
    Gusthavo Rookie
    Aug 5, 2024
    2
    Gusthavo
    I went to close the door of the SF 90, and to avoid slamming it too hard, I used the handle gently as a "lever". As a result, the door remained ajar and did not close. I pulled it again to close it, and when I slammed it, it ended up stuck partially open (unable to open or close, even when locking and unlocking the car with the key).
    Was this due to the way I closed the door, or was there some kind of defect in the car? How can I resolve this safely?
    Thanks in advance
  2. BAK5150
    BAK5150 Rookie
    Aug 24, 2024
    24
    London
    Burhan
    One
    This does sound like it may be to do with the way the door was closed, however the e-latch can fail so if this issue isn't sorted already one thing to check is if it says e-latch fail on the dash then one thing to possibly try may be a battery disconnect.
    Edward 96GTS likes this.
