SF90 door won't open or close | FerrariChat
Discussion in 'SF90 Stradale' started by Gusthavo, Aug 6, 2024.
  1. Gusthavo
    Gusthavo Rookie
    Aug 5, 2024
    2
    Gusthavo
    I went to close the door of the SF 90, and to avoid slamming it too hard, I used the handle gently as a "lever". As a result, the door remained ajar and did not close. I pulled it again to close it, and when I slammed it, it ended up stuck partially open (unable to open or close, even when locking and unlocking the car with the key).
    Was this due to the way I closed the door, or was there some kind of defect in the car? How can I resolve this safely?
    Thanks in advance
  2. Cocoloco
    Cocoloco Formula 3
    Nov 26, 2013
    1,354
    Go in thru the passenger side and use the inside handle or lower top if it's a spider.
    I haven't had one problem besides a loose wire / quick fix and drive it most days of the week.
