Shaky taillight fix | FerrariChat
Shaky taillight fix
Discussion in '360/430' started by Sky Hye, Apr 21, 2018.
  1. Sky Hye
    Sky Hye Formula Junior
    710
    SoCal
    Finally after months of work, I’ve perfected the shaky tail lamp fix. My inner left tail lamp studs were completely severed and two more lamps had cracked studs. I looked around and the kit available was a bit much for me and didn’t fix the broken stud problem I was having. Results are great and going a few months strong without any wobble or cracks. I have a patent pending so China won’t rip me off hehe.
    If there’s interest I’ve been getting requests for kits and would be willing to sell some
    ShineKen likes this.
  2. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,965
    houston/geneva
    Ross
    thats pretty nifty.
    i super glued mine, then wrapped them very carefully with red duct tape pieces, then reattached it putting a rubber bushing in between to absorb the vibrations.
    i have done this to two taillamps so far. all still good.
    btw, can you imagine what a bad design this is??
  3. Sky Hye
    710
    SoCal
    As an automotive engineer it’s embarrassing. Especially knowing it’s been an issue on all years! Wonder if 360 or 458 has this issue too.
    Great fix. Looks like you did a good job too.
  4. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,944
    UAE
    Serge
    had similar issue on one of the taillights on my 360 a few years ago, JBWeld helped.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    i Just cut the plastic post back and drilled it for m6 stud bar. Still going strong after 3 years. There are some pics on here somewhere
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    If you can make the single post solid then the other two seem to be ok. I cut the post back, drilled and tapped 6 mm and loctited the stud bar into it, then the first nut is set in its final position and loctited in place, the 2nd nut acts as normal
  7. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,405
    Northern CA
    Yin
    Do not conduct business on this thread. Posts moved.
  8. Daron
    Daron Rookie
    Mar 18, 2018
    8
    California
    Daron
  9. brogenville
    brogenville Formula 3
    2,261
    Robin
    janmante and Gillis Haasnoot like this.
  10. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,321
    Maryland
    Mark
    So did BMW lol
  11. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I have found that the bottom screw post for the brake light piece fails too. Anyone have a support for those?
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Just look at the pics of my fix above, only takes 10 mins to do if you have the gear. You dont need a support this way
  13. colorfull
    colorfull Formula 3
    2,332
    Franklin Park, New Jersey
    John Napoli
    So mine (F430), at least as far as I know, are intact, they don't move. I'd like to prevent an issue and was considering the kit referenced by Sky Hye at the top of this thread
    Any other prevention recommendations?
    Thank you!
  14. Jgivoo
    Jgivoo Formula Junior
    436
    New Jersey
    Sky Hye's kit has the rubber grommets. If you were to install just the rubber grommets prior to any failure, that would definitely help in dampening the vibration which seems to be the cause of the failures.
    colorfull likes this.
  15. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    The brake bulb screw post on the bottom. The plastic degrades so much that there is barely anything left.
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Not sure which bit you mean, is that the single post to attach light to the car or where the phillips head screw , screws in.
  17. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
  18. Sky Hye
    710
    SoCal
    Yea, buy my kit! Haha
  19. Gillis Haasnoot
    Gillis Haasnoot Karting
    Feb 4, 2020
    104
    Leiden, Netherlands
    Gillis Haasnoot
    If someone has a cad file of the lamp unit I can create some brackets and share the STL files or send them via post. Creating some brackets is quite easy once I know the surface dimensions of the lamp
    janmante likes this.
  20. SingleClutch
    SingleClutch Karting
    Apr 19, 2019
    120
    Seattle
    Kris
    I just replaced all my bulbs with LEDs last night, and I had one lens post completely broken off and on two of the lenses the plastic had broken where the bulb cluster screws into the housing. I was able to epoxy everything for now, but I ordered new replacement lenses from Scud Ing (scuding.com). Image Unavailable, Please Login Image Unavailable, Please Login
    Fly fast and take chances
    Sj_engr likes this.
  21. AandSC
    AandSC Formula Junior
    947
    Jax, FL
    Allen
    I installed the Scud Ing Swiss taillights but used Sky Hye’s reinforcement kit as it appeared they could suffer later on from the same issues the stock lights have.
    SingleClutch and janmante like this.
  22. janmante
    janmante Karting
    176
    jan mante
    Nice ! are they available ? are you sharing the file ? have you done some reinforcement for the other brake light post that fails ? thx Jan
  23. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    If this is broken, how much is left and can you drill and tap a thread into it. If so then do so and epoxy in a length of stainless stud bar, then use a nylock to secure the bulb
  24. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    A few mm. What I did was try and epoxy a small metric nut into the place after cleaning up the surface with a dremel. If I did it again I would use a nylon nut and scuff it up with sandpaper. On one of the two tail lights that needed this work the steel nut spun out of the epoxy when tightening.
  25. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Look on Amazon for AVK inserts- they are a steel sleeve with threads inside. They are normally fitted to recover a thread and fitted similar to pop rivits. But you can drill out a hole and apoxy them in place
