Sheehan - QV with improved different pistons and rings? | FerrariChat
Discussion in 'Mondial' started by braq, May 23, 2022.
  1. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Does anyone know more about the QV engines having "improved" German-made pistons and rings used on the four-valve engine? Mahle comes to mind, but was there really a switch, and has anyone practical results gotten from it?
    Find the claim in here
    https://ferraris-online.com/low-buck-horsies/
    Cheers
    Bracq
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,668
    Argent/Brasil
    Guido
    I like this quote = If you’re clever, your neighbors will refer to you as “the guy up the street who must have won the lottery because he’s driving a Ferrari.” If you’re not, they’ll remember you as “the guy who used to live up the street but ended up selling his house because his Ferrari needed a new engine.”
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    KS Pistons ( Kolbenschmidt) are very good
  4. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    There certainly was a change as Mondial 8, 308 carb and 308i-2V use a piston with 4 piston rings and Mondial QV and 308QV use a piston with 3 piston rings. What confuses this issue is that some early 2Vi engines had some sort of ring seating problem so used a lot of oil, and led F to develop the ridiculous warranty specification that "if it uses less than 1 quart of oil in 600 miles (1000 Km), it's OK, and we are not replacing the engine for free" ;). F still uses this specification on many models that followed, but no engine in decent condition uses this much oil. Later design is always better, but no one is taking a good-running 2-Valve and is in a panic to replace the pistons. There is some risk that an early 2Vi engine might have an oil consumption problem if never fixed, but, if it's had regular use, any problem in this area should have already surfaced:
    308 carb: Special Cast Iron Liners, 4-ring pistons
    early Mondial 8, 308i-2V: Special Cast Iron Liners, 4-ring pistons (some risk about excessive oil use and many had engine replacements)
    later Mondial 8, 308i-2V: Special Cast Iron Liners, 4-ring pistons (they did some fix)
    Mondial QV, 308QV: Aluminum Alloy Liners with Nikasil coating, 3-ring pistons
    But QV do get a price premium for this and other issues.
    ellum likes this.
  5. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Steve, great info from you. I had always thought 3 rings on a piston and that's that, who knew ;-)
