SHELL HELIX | FerrariChat
SHELL HELIX
Discussion in 'Technical Q&A' started by dan1059, May 30, 2006.
  1. dan1059
    dan1059 Rookie
    Apr 1, 2006
    7
    Maryland
    Daniel Schmidt
    Any idea WHAt oil filter brand I can use for my 1984 308 and any idea where to get the Shell Helix oil?
  2. DGS
    DGS Seven Time F1 World Champ
    73,023
    MidTN
    DGS
    FOW can probably get you both the UFI filters and the Helix.
    Original spec was UFI and Agip.
    Check http://ferrarichat.com/forum/showthread.php?t=64460
    Try Fchat's search engine ("search" on the upper menu) to get more than you ever wanted to know about engine oil. Helix generally isn't worth the hassle and mark-up in the US. Ferrari of Washington can probably score some Agip for you, or you could google for a source.
  3. Cyclocharger
    Cyclocharger Rookie
    May 24, 2006
    27
    St. Petersburg, Fl.
    David Reynard
    I responded to this on another thread. After sufering from poor shifting and lose of HP I was convinced to use BG Ultraguard and WOW what difference. It is a little expensive, around 19.00 a quart. Even though the Shell recomended fluid came out looking unused and no debris on the pick up magnet appearently it can gum up the syncronizers.
  4. f355spider
    f355spider F1 World Champ
    18,055
    Many of us use Mobil 1 0w-40 instead, much cheaper, high in quality and easier to find. Use either the UFI or Baldwin oil filter...and NOT the Fram...which has quality control problems.
  5. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    What is the Baldwin and UFI Part # for an '87 TR oil filter? Please..........
  6. Tifoso Ferrari
    Tifoso Ferrari Formula Junior
    Nov 7, 2005
    578
    Upper Volta
    Gianni Cagate
    The plate riveted to the front of my 575M's radiator states that Ferrari recommends Shell Helix 5W-40. At nearly $20/qt I think it's ridiculous! I went with Red Line 5W-40 (http://www.redlineoil.com/) and can not tell the difference. Red Line is less than 1/2 the price, too.
