Shift Linkage/Rod adjustment | FerrariChat
Discussion in 'Boxers/TR/M' started by 90TR, Mar 5, 2011.
  1. 90TR
    90TR Formula Junior
    Nov 23, 2005
    274
    Celebration, FL
    Bill
    #1 90TR, Mar 5, 2011
    I am having trouble finding the right alignment when reconnecting the Shift linkage rod to the Transmission. What is the correct process to get this aligned properly? Thanks again, Bill. #43 in the image below:
  2. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    Tried to upload directions but looks like I am maxed out on posting pictures ability. Sorry.
  3. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Do a search on Testarossa clutch by me. I have a full explaination from Rifledriver on it. He and Tom Tbakwoskey walked me through it. It's very time consuming and a super sensitive adjustment.
    Gee...if we had a Testarossa tech sticky...just sayin' ... :/
    Shamile
    Freeze....Miami Vice !
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Now me too!!!!!! :D
    Who is the goderator of all things Testarossa that we need to convince????
    P
  5. mwr4440
    57,931
    Bavaria, The 'Other' Germany
    Mark W.R.
    #5 mwr4440, Mar 6, 2011
    Shamile,
    Looks very similar to a 308. If so, it can be done in about 15-25 minutes if you have the tranny pan off so you can see what you are doing and an assistant.
    Doing it alone would take considerably longer becuase you would have to check each adjustment no matter how slight.
    A shift lever centering block would make the task much easier if one works on the TR like the 308. Then your assistant need is pretty much negated. I just aligned it and tightened it all up using the "2nd-3rd-Neutral" procedure using my calibrated eyeballs. Not nearly as easy but that is all I had.
