Shift Stick Snapped in two! | Page 2 | FerrariChat
Discussion in 'Mondial' started by paulchua, Jun 19, 2018.
  1. cloverleaf
    cloverleaf Karting
    Jun 16, 2013
    92
    In the interest of science, could you share a close-up picture of the fracture surface? Thank you
    paulchua likes this.
  2. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    The Netherlands - NH
    Tijn
    I put my money on the rod where it wears on the gate. I have seen already the wear when I took it apart.
  3. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Sadly part of the joy of the ownership of these gorgeously machines! Glad u are able to fix it!
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Paul, you might consider one of the Hill Engineering slick shift gates to help reduce stress on the new part.
    Good luck getting it all back together.
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    Thanks for all the kind words! I'll post more of the requested closeup picture and let you know all how it goes and the procedure of replacing it.
    Cheers
  6. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    That's correct, I stuffed it into 2nd gear and just drove (very slowly) home. It should be easy to weld, but I wanted a permanent solution so I figured I would just replace the whole rod. Btw, looking at some 308/328s this week, I think the 348/355 rod is thinner? Maybe just an optical illusion.
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    just ordered, thanks Mike!
  8. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    I was going to say - I've never heard of this! Crazy.
    Glad you were able to avoid the shame of a tow truck ride though. Haha.
  9. NYC Fred
    NYC Fred F1 Veteran
    9,710
    Fort Lauderdale, FL
    Fred C
    Somebody's gonna build a GTO from it.
    davemqv and paulchua like this.
  10. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    Ernie had the same problem with his shift rod on the 348. Of course, he has many problems including his rod.
    ///Mike and paulchua like this.
  12. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    Here ya go!
    cloverleaf likes this.
  13. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    HI JLF,
    Yes, so you put the car on a lift and detach the shift linkage cables. You open the central console and then lift it up out of that center unit. It's not bad if you have a lift, if not - much harder. On the scale of difficulty, definitely on the lower end. Keep in mind that this link is for the 348 which has similar mechanisms - but the box itself is different. Not sure how compatible the other parts are, so YMMV.
    Just as an FYI - the car has 60K miles, so hopefully that gives you all an idea of how much shifting before the rod failed. The new one has 20K so hopefully it lasts longer. I also am installing the Hill Engineering fast shift - maybe that will help. Also, not sure if certain 'batches' were just worse. Hope this help you all my friends.
    Cheers
  14. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    Thank you MvT for your links and your comments. Talking to a few folks, it's more common then any of us would believe! I don't know if there is variances in quality from rod-to-rod. Also, I don't think I've overly aggressive with my shifts (been driving stick for 30+ years) - maybe the track driving took it's toll on the rod? Either way, one last piece of advice. If it ever happens to you, be careful with the breakpoint - it is VERY SHARP, and will cut you. Try to get a rag or other mechanism to push to 2nd gear. It will allow you to eventually get to your destination (albeit grandma speed style)
    Cheers
  15. davemqv
    davemqv F1 Rookie
    Aug 28, 2014
    3,121
    Dave
    Sounds like Hill Engineering has a new product to build....
    Tempered Stainless Steel Shifter shafts for your Ferrari!
  16. JLF
    JLF Formula 3
    1,657
    Thanks Paul. Are you planning on replacing that bushing while your in there?
  17. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    Everything installed and ready to go! The Hill Engineering shift gate was not a marketing gimmick - the thing works. Shifts in all gears much easier and smoother. No brainer mod, $140 and 5 minutes for a lifetime of smoother shifts. I didn't change the bushing though (hopefully we don't see failure) - I did grease and clean the heck out off the mechanisms while I was in there!
    Cheers
    alexion likes this.
  18. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Glad it worked for you, Paul. And glad you got it working again. :)
  19. alexion
    alexion Formula 3
    1,313
    New York
    Happy motoring!
  20. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Paul,
    Dont touch the steroids in the future ! :p
    Guido
  21. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    UPDATE: Since replacing my gear shifter assembly, I noticed I no longer have 2nd gear hesitation when cold. I always thought it was a function of oil; No complaints at all. But I thought I would report it here.
    Jasonm96, gsfent, Pero and 1 other person like this.
  22. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,093
    Menlo Park, CA
    Paul Chua
    I thought I would clarify, I still have slight hesitation in 2nd gear when cold, just nowhere like how it was before. I can still put it in 2nd, even when cold, of course it’s much smoother once temps go up, just that before install it was a complete no go skip for at least 5-10 minutes.
