348 - Shifter help. | FerrariChat
348 Shifter help.
Discussion in '348/355' started by JLF, Apr 23, 2019.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    I removed my shifter from my mondial t. I followed the broken shift lever thread but when I take the center bolt out the shifter mechanism will not come out from the housing!
    I did this because of an internal rattle at high rpms. Do you know what may be causing the rattle?
    Jerry Image Unavailable, Please Login Image Unavailable, Please Login
  2. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    Never mind I got it apart.
    The only thing I could see that may cause the rattle is that I could slightly wiggle the shift pole around when the 2 pieces that hold it in were together. Would you recommend ordering a new shift pole?
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Searching here at FerrariChat doesn't result in many posts that describe a problem similar to yours.
    But these might help:
    ;) for the second one.
  4. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    Thanks Wade.
