Shifting Problems | FerrariChat
Shifting Problems
Discussion in '308/328' started by Ferraripilot, Jun 25, 2006.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    Hello Everyone~ I have taken delivery of the '76 308 from Fantasy Junction. The car is immaculate. I do have one question for you guys though.
    Once the transmission is fully warmed up, it has difficulty shifting. I spoke to the mechanic who has worked on the car since new. He is the only person to touch the car. He stated that he adjusted the linkage just a couple of months ago due to the complaint of the difficulty shifting while hot. Could this be a clutch problem? The mechanic who worked on the car said that it very well may be a clutch issue. What do you guys think???
    PS> The car has always had swepco gear oil in the gear box.
    Thanx very much in advance, J.
  2. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Any specific gear or all of them?
    Ciao
    Eugenio
  3. Fengtau
    Fengtau Formula Junior
    Dec 25, 2004
    358
    Malaysia
    The same problem happened to my client recently.Replaced the clutch set-problem solved!
  4. ParadiseRoad
    ParadiseRoad Formula Junior
    Mar 26, 2006
    538
    Colorado
    Difficulty shifting into gear from neutral is most likely clutch related. Is this the problem?
  5. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    First gear engages well. Once the box is warm, the rest of the gears do not want to shift at all. I even hear the syncro's working a little but, I do not want to force anything so I always back off. This still sound like a clutch issue? If so, will do.
  6. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Try changing the gear oil, I don't think swepco is good for Ferrari boxes, then I'd try the clutch, could be an adjustment issue as well he might not have adjusted it perfectly.
    I use slick 50 gear oil and both my F cars shift like butter.
  7. yank05
    yank05 Formula Junior
    Nov 8, 2003
    272
    New England
    Anthony
    Hi,
    Congratulations on the purchase!
    From your description, sounds like a clutch or linkage issue. It should at least shift into gear with fresh gear oil (of any kind).
    Anthony
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    Mine is the opposite, its difficult to shift when its cold and easy to shift once its warmed up.
  9. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    If the clutch has already been adjusted it may be time for a new clutch....not sure on a 308, but your probably looking at around $3,500.00. Hard shifting is common when cold, but when warmed up shifting should be smooth and fun.
  10. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,564
    Sacramento Ca
    Colby Sandman
    Where on the pedal does your clutch engage? This is a way to tell how worn the clutch plate is. A good clutch will engage somewhere in the middle range of the pedal throw, a bad one will usually creep towards the end of the pedal travel. The problem you describe would mean the clutch isn't diengaging all of the way, this could be a hydrolic problem. Check the fluid in your slave cylinder resavoir also.
  11. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    308 clutches use a cable, no slave cylinder.
    Dave
  12. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    You sure about that?!
    Sounds like a clutch and a Las Vegas weekend getaway at the Bellagio with a dinner-of-a-lifetime thrown in.
  13. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    Just an estimate.....dealer quote on my 328 was close to 4k for a clutch if needed and another 5k plus for the 30k service.....sold the car instead.
  14. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    That's a shame. 308/328 clutch replacement should be between $1400-$1700, max, parts and labor (on the East Coast, at an independent). The major can run to $5K, but is not usually that much.
    -Peter (just finishing a major on a 15,000-mile 2V injected red/black 308)
  15. Bullfighter
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    That's similar to what I was told by my mechanic here in San Diego.
  16. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    Dealer quote over the phone....the dealer doesn't have any competition here....basic 328 30k service starting $4,900, told probably closer to 6k....told would be higher if car needed brakes, clutch, tires. When I ask the price of the clutch he told me it could be up to 4k.
  17. Ferraripilot
    May 10, 2006
    17,849
    Atlanta
    John!
    Hey everyone. I fixed the ****ing issue over the 4th of July. I drained the tranny oil and replaced it with Mobil 1 gear oil. Problem solved. The car shifts flawlessly. The magnet on the drain bolt had a few metal hairs on it but nothing at all alarming.
  18. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Congrats on the new purchase!
    There's a fairly recent thread somewhere on here about gear oil. Redline seems to be a favorite. Some people have also had good success with Mobile 1. You'd be surprised how many have had similar problems solved with a simple change of gear oil.
    Glad to hear you got it fixed. Enjoy the ride!
    FWIW: My friend had his '88 Mondial 3.2 clutch done 2 months ago here in LA.
    It cost about a grand from Italcarguy's dad.
  19. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Correction: About $1500.00
  20. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    same here in Florida, about $1,400
  21. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    £450 in the UK... Mark328 where do you live?
