Shifting problems | FerrariChat
Shifting problems
Discussion in 'Ferrari Discussion (not model specific)' started by Donatas, Apr 20, 2022.
  1. Donatas
    Donatas Rookie
    Nov 14, 2018
    21
    Donatas
    Hi everybody. The 2 gear shifting problem have all Mondial models, or only Mondial T? Thanks for answers!
    paulchua likes this.
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,656
    South East
    Jimmie
    If you refer to the difficulty shifting into second when cold this applies to pretty much every 5 speed Ferrari
    DrewH and 19633500GT like this.
  3. 83Mondialqv
    83Mondialqv Formula Junior
    May 18, 2021
    338
    New York
    Vito L
    My 83 Mondial does it too shifts hard into second when cold. All gated ferrari have this problem one way to resolve it is start from second gear instead of first
  4. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,143
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Or skip 2nd gear until the gearbox warms. It is also a good way to be nice to your engine while it is still waking up.
    19633500GT likes this.
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,411
    Menlo Park, CA
    Paul Chua
    It's very common, although what I found really helps is just making sure the shift linkage is just tightened up. It's not straightforward, and I wouldn't do it unless you need to open up the shift housing anyways. Make sure the connections are tight from the shift lever mechanism and through under the car, follow the two red cables and make sure it's tightly connected to the linkage box. Basically, just make sure everything is taught. It won't make it go away entirely, but it did make it less balky for me. I did this myself and found it helped.
    Regardless of what you do, after 10 minutes though it should be smooth as butter.
    The gated to this day is one of life's pure pleasures. Truly.
    DrewH likes this.
  6. Dave Bertrand
    Dave Bertrand Formula Junior
    823
    Castle Rock, CO
    The problem with this is that you also are not supposed to exceed 4k RPM until the oil temp has warmed up. So, if you start in 1st gear and shift straight into 3rd gear without going over 4k RPM in first, then unless you're going downhill you are lugging your engine in 3rd after the shift. Basically you have to drive like granny on the way to church for the first 5-10 minutes.
  7. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,143
    1983 US 308 GTS QV
    The revs can be kept below 4k with a 1 to 3 shift. I suppose I am "lucky" in that my neighborhood is zoned 25 mph. I can let the grannies pass me as I doddle along while the engine warms. I have always been impressed with how much low rpm torque the engine has.
  8. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,411
    Menlo Park, CA
    Paul Chua
    Agreed, the low-end torque is not bad at all!
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,411
    Menlo Park, CA
    Paul Chua
    Supposedly, drilling a small hole will solve it. Don't know if this is true...
    Here is a thread.
    also tech article attached
    So proceed at your own risk.
  10. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,411
    Menlo Park, CA
    Paul Chua
    Also start with the easiest thing, try changing your transmission oil first. I use redline for 10 years, love it
  11. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Redline gear oils will solve the issue.
    Ali
  12. Dave Bertrand
    823
    Castle Rock, CO
    Which Redline gear oil? They makes 6 or 7 different kinds.
  13. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,143
    1983 US 308 GTS QV
    #13 Brian A, Apr 25, 2022
    At least for the 308 GTS/GTB, the most appropriate Redline gear oil is generally considered to be MTL.
    A good gear oil maximizes performance of the gearbox but may not completely eliminate the cold shift performance of second gear. The problem is partially related to the design of the gearbox itself.
    FWIW, my gearbox doesn't seem to mind being shifted into second while cold. Despite this, I still skip second until the engine warms a little.
    Dave Bertrand likes this.
  14. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    I use Redline or the Shell full synthetic, You will find that 2nd gear becomes easier. Now mind you, I have always used syn gear oil, my 328 has 104,000 miles, and I have never had a problem with 2nd gear cold shifts .Make sure your blipping the thin pedal on the right in between shifts, that gearbox loves it .
    Thank you
  15. DrewH
    DrewH F1 World Champ
    19,401
    Vancouver, BC Canada
    Andrew
    6 speed gated shifters also.
  16. vandevanterSH
    vandevanterSH F1 Rookie
    3,167
    AR
    Stephen Van Devanter
    1st to 3rd in my 575m manual until things have warmed up.
