Shock actuator fault after KW coilover conversion | FerrariChat
Discussion in '456/550/575' started by MonzaMonza, Mar 15, 2017.
  1. MonzaMonza
    MonzaMonza Rookie
    Aug 5, 2016
    3
    Nashville
    Hi all,
    I've recently swapped the suspension on my 550 Maranello for the KW V3 Coilover Kit (PN: 33642022) and the ride difference is amazing. I use KW suspension on all of my Porsche's and track toys- they never fail to disappoint.
    However this time I've run into an issue. The shock actuator light comes on and will not turn off on the central display. It's basically the silhouette of a car with arrows pointing to the wheels. After a quick search I found this to be more than likely the result of the KW coilover swap.
    I talked to a Ferrari shop in Washington where they noted that this can be turned off, but didnt really explain how. I never had an issue with the warning light prior to swapping the suspension and I know that the actuators are fine and operate as they should (Ferrari shop inspected the gears and gave me the green light), however the light is a bit of an eye sore. My previous 355 coupe also had KW's and the shock actuator light wasn't illuminated or throwing any faults.
    So I guess this goes out to anyone with a similar experience with a conversion on 355's/456's/550's/575's. Is there any way to bypass this monitor? It's just an eye sore and the only solution the local Ferrari dealer had was to replace all of the actuators which came out to some insane amount of money, just shy of $6k or in that territory.
    Any and all help would be truly appreciated, thanks for reading.
  2. tres55
    tres55 F1 Rookie
    3,572
    Canada
  3. FPFaeth
    FPFaeth Formula Junior
    Dec 3, 2009
    663
    NY
    Frank Faeth
    When I had my 550, we had to replace the crown wheel on top of the right rear shock. As a result, we kept throwing codes. Dan MacKay at Bradan figured it out after a considerable amount of investigation. You might want to contact him to save time/money.
  4. MonzaMonza
    MonzaMonza Rookie
    Aug 5, 2016
    3
    Nashville
    That's the thing though, none of them have failed - the tech pulled all four out and tested them, all gears were operating normally. Which leads me to believe it might be some kind of electrical gremlin. ECU reset didnt do a thing either.
    Thanks for the input, sounds very similar to what I'm experiencing. I know the KW setup is fit for the 550 and many owners have done the conversion with no error. I'm assuming it's an electrical gremlin of some sort. I will certainly reach out to Dan and hopefully he'll be able to shed some light on the matter. Thanks a ton.
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Just a thought as I have my own suspension apart. When removed, my actuators on startup spin much further than the shocks would allow when the actuators are installed. Meaning, it seems like the suspension ECU learns the stop point at each startup. Perhaps your new shocks have a different travel limit and the ECU thinks it's a failure?
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    A possible cause for the suspension warning light when everything else checks out OK is that one of the Hall effect wires has a cold solder joint failure. The actuator motor will still turn both ways on the bench but will not communicate properly with the suspension ECU.
    A comparative resistance test with an Ohm meter between actuators might help determine
    which one has an open circuit.
    See this post :
    http://www.ferrarichat.com/forum/139904900-post27.html
    Other causes are mentioned in this thread:
    http://www.ferrarichat.com/forum/technical-q/209629-shock-actuators.html
    I have repaired many actuators and seen this cold solder joint failure several times, it is not particularly rare.
    NB: I don't repair these this any more so please don't ask.
    Worst case cutting the green/yellow wire at the lower yellow connection at the shock ECU will turn off the light. It will come on as a bulb test for about ten seconds on startup then go out.
    F456M likes this.
  7. fatbillybob
    Aug 10, 2002
    28,999
    socal
    Wait a minute...Isn't this co conversion shock and spring? If yes then you can't use the ferrari oem actuators system. The oem system is only bilstein or sachs on the maranello versions. If I'm right then you need the simple and proven modification of the suspension ecu from our resident genius "ferraridriver" dave.
  8. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #8 ferraridriver, Mar 16, 2017
  9. asb9987
    asb9987 F1 Rookie
    Dec 4, 2004
    4,191
    Toronto
    A. B.
    It's giving the fault because your KW coilovers are not adjustable electronically. Your car is searching for electronic shocks but there are none. The connector are not hooked up to anything, hence the fault. You need a fault canceller or have the dealer reprogram the car to disable electronic dampening control.
  10. brogenville
    brogenville Formula 3
    2,267
    Robin
    Hi Guys,
    Struggling to find the details on what to do to get rid of the suspension warning light on a 550 when you've changed out the electronic dampers for aftermarket coilovers. I understand the suspension ecu needs to get unplugged, then a couple of wires on the connector get bridged? Can anyone share the details of the relevant pin numbers that need bridged?
  11. brogenville
    2,267
    Robin
  12. brogenville
    2,267
    Robin
    Apologies - this diagram relates to the ABS ecu. Ignore then! Does anyone have the right pinout diagram for the suspension ecu?
  13. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    In what way is the car better with this new shocks and springs? I thought the whole point with the computer controlled original system was to adjust each shock individually for every imaginable situation. By reading the manual, it shows that the system firm up the outer shocks in a turn, front when braking and rear when accellerating etc. I thought that was an ideal way to give more stability to the car?
  14. tazandjan
    39,169
    The kits usually include a bridge to fool the actuator controls and suspension logic. Contact the manufacturer or his retailer. There are many things that can give a suspension fault, and you want all of them bypassed.
  15. brogenville
    2,267
    Robin
    Higher quality components with more adjustability, greater dynamic range for tuning, greater fluid volume to cope with heat better...
    Basically a variety of reasons. Not saying the OEM stuff is bad, but it’s pretty old tech now.
  16. Qavion
    Qavion F1 World Champ
    14,289
    Ian Riddell
    We have a wiring diagram, but no clue regarding the pins to short out. Two wires go to the motor in each actuator and the other four going to each actuator are unknown.
  17. brogenville
    2,267
    Robin
    Able to post the wiring diagram?
    I've gone through loads of old posts, and there are numerous references to a "well established " means of bypassing the suspension ecu for aftermarket coil-overs. It may be obvious form example if there is a pin for "fault condition" that feeds into another ecu that can be bonded to earth or 12v to send a confirmation that no errors are present. I honestly don't know, but the wiring schematic would certainly help. :)
  18. stan996turbo
    stan996turbo Formula Junior
    Jun 11, 2004
    711
    Philadelphia
    Stan
    I’ve been thinking about trying KW coilovers on my 550 and would appreciate any further review of the differences from stock suspension. Thank you
    white out likes this.
  19. Qavion
    14,289
    Ian Riddell
    That might be a clue... The suspension fault wire goes into the instrument panel (labelled 300 in the diagram) on pin 10 of plug "B" on a green wire (with yellow stripe). i.e. colour code VG.
    This green/yellow wire comes out of the Bilstein suspension unit on plug A pin 10. I can't remember if plug A or B is the yellow plug. From memory, however, the wires are not visible at this end of the harness. You have to pull the plugs apart to access the wires. It may or may not be easier to add your earth(?) at the instrument end.
    https://www.dropbox.com/t/b3XhvnacahpluuNf
    Link expires in 6 days...
    The 456M shares a lot of the wiring with the 550. The plug at the instrument panel will be similar to plug "37F/11F" in this screenshot from the 456M workshop manual.
    The 456M pinouts show a wire colour change at this plug from green/yellow to yellow/green. The 550 may or may not have this colour change (the diagrams are in a different format and don't have this data).
  20. Qavion
    14,289
    Ian Riddell
    For easier location of the wire on that plug, the green/yellow wire is between a grey/blue (HL) wire on pin 9 and a grey/white (HB) wire on pin 11 (i.e. on the car side of the plug, not the instrument panel side of the plug)
    Ferrari55whoa likes this.
  21. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    You know Ferrari 456/550 10x better than the average Ferrari tech!! What a contribution. Thanks for sharing.
    Qavion likes this.
  22. brogenville
    2,267
    Robin
    Many thanks Ian!
    Qavion likes this.
  23. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    From March, 2017
    white out, brogenville and F456M like this.
  24. brogenville
    2,267
    Robin
    Many thanks! I thought this might work. You know if this can result in any limp mode behaviour? Or does the bilstein ecu operate independently?
  25. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    As far as I know it only breaks the connection to the light
    As I understand it you no longer have the OEM shock actuators, if so the Bilstein ECU can not do anything but power the suspension warning light. With that wire cut it's redundant.
    This would give you the freedom to replace the Sport switch with something more usable since it's also redundant
    brogenville likes this.
