Shock bolt hitting control arm with QA-1 | FerrariChat
Discussion in 'Technical Q&A' started by BillyD, Jun 14, 2010.
  1. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    I've been chasing a knock in the rear suspension of my 308GTB every since I installed the recommended QA1 shocks & springs. It looks like the head of the bolt that mounts the lower end of the shock to the hub strikes the control arm on bumps. This is not a problem with the stock Koni & springs as I don't believe the suspension ever compresses to this point. I did each corner individually so I don't believe I mixed up the left & right upper arms but if anyone has a picture of their arms to verify this I'd appreciate it. I'm about to do a little grinding on the control arm for clearance. I put the stock Konis on temporarily & there is no way I can live with the 4 wheel drive stance now that I've seen it lowered.
    Suggestions and experience wanted.
    Bill
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Bill,
    I believe you need a set of, "paperweights" from Birdman.
    Good Luck,
    Edwardo
  3. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    Thanks but paperweights are installed on the front & this is on the rear.
    Anyone? Bueller? Bueller?
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,653
    Hell's waiting room
    I don't have that problem Bill. Did you lower it way down? I only dropped mine a bit. Actually I didn't have that problem in front either but I went with a slightly different model of the QA-1 shock.
  5. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Better yet, grind the bolt if you can.
  6. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    #6 Dave, Jun 15, 2010
