Shocks other than Koni or QA1 | FerrariChat
Discussion in '308/328' started by Jasonious, Mar 4, 2020.
  1. Jasonious
    Jasonious Rookie
    May 13, 2018
    42
    PNW
    Hello Everyone
    Since I have my car in the air, I have been considering options to replace the 40+ year old shocks and springs. I am quite familiar with the Koni's and have read all of the threads I could regarding the QA1 solution and agree they are both viable and affordable options.
    I notice now that there are European parts outfits in Germany and Italy that sell Bilstein B16 (adjustable) and B14 (non adjustable) solutions for the 308 at semi-reasonable prices. Has anyone fit these to their car? I am specificly considering the B14 option with spring rates of 60 N/mm front and 50 N/mm rear, although 60 front and 60 rear has also been recommended.
    Is the current thought still that a *GTB* should have a different rate front to back?
    I know in the past that that was the norm, but I also see from factory literature that the GTB's, at least, came with the same rate front to back.
    Looking for opinions!
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    You don't cite your motive for the change. If its just time related, you might consider just getting your factory Koni shocks tested first.
    I just had my shocks tested on a shock dyno and was very surprised to learn that they performed as well as new shocks: no performance degradation after 37 years. I'm just putting them back on the car (with custom lower spring perches to lower the car a little bit).
    thorn and Thomas Magnum like this.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
  4. sltillim
    sltillim Formula 3
    1,701
    San Diego
    I just reached out to KW USA - I was looking at their V2 or V3 model. They will ask you to do a competition build. They would not share a ballpark price. I am more inclined to go with Intrax out of The Netherlands. HotShoe and a couple others on here have them and I am probably going this direction. They have an add on feature called ARC that prevents body roll without over springing the car.
    QA1 or Koni Rebuild is probably $1500 - 2K all in.
    A good suspension is $3-5K
    Very expensive real competition level is probably more like $10K (like penske or real race stuff). This is an expensive hobby...
  5. Jasonious
    Jasonious Rookie
    May 13, 2018
    42
    PNW
    I've have good luck with Bilstein and Eibach combinations in the past and the Bilstein solution for non adjustables is 2.5K all in shipped to your door, so not much of a stretch over the Koni rebuild.
    Curious about the expierience, if any, others have had with them on their 308's and also curious what the new recommended spring rate combination is or if if it's not changed in the past few years. Does 60N/mm 50N/mm sound good or should it be 60 front and back?
  6. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Do a search on Gaz shocks here in the UK. I might get some so can call about a group buy if others are interested. External shock adjustment and adjustable height.
  7. Nino1964
    Nino1964 Formula Junior
    302
    North Georgia
    I used Spax and have been pleased. Direct replacement with no crazy mods. I have my oem Konis packed away.
  8. 4right
    4right F1 Rookie
    Give True Choice a call. 888-566-4722 ask for the Koni Racing Services. They can rebuild your Koni's with threaded sleeves so that you can adjust the ride height.
  9. Jasonious
    Jasonious Rookie
    May 13, 2018
    42
    PNW
    Thanks for the replies everyone. Any specific guidence on spring rates? Does 60N/mm 50N/mm sound good or would 60 front and back be better?
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,222
    Gold Coast, Aust.
    Patrick
    +308
    I had shocks and springs made by them and shipped out to Oz - still cheaper than getting the Konis rebuilt, or even QA-1's. Mine are a little soft for my liking, but they could have been specced harder - we were sort of guessing where to set them at the time. I think I had the second set ever made for a 308 (Andy had the first)
  11. Dr Tommy Cosgrove
    36,449
    Birmingham, AL
    Tommy
    The older I get the less interested I am in these "upgrades"
    As I type this, just to my left are two boxes containing STOCK springs and (as close as I can get to ) STOCK shocks for my Alfa Spider. I'm undoing all the things I thought was cool when I was 25.
    syata, Nuno Andrade, hyenahf and 3 others like this.
  12. Jasonious
    Jasonious Rookie
    May 13, 2018
    42
    PNW
    I went with the Bilstien B14 with 60 N/mm front and back. I'll give a report once I install them. Hey, if Bilstein were good enough for Carlo Facetti, should be good enough for me! :)
  13. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    Nick Forza sells Alden Eagle. in and out and hight adjusable
    They make a set specially for the 308 for a very reasonble price.
  14. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    ive had koni classics, koni reds, koni yellows, and bilsteins over the years, the stock spica dampers are simply wonderful... they are hard to find new these days. im pulling out the hot motor and dialing back suspension since i dont track the car anymore
    Dr Tommy Cosgrove likes this.
