Shorted rotor | FerrariChat
Shorted rotor
Discussion in '308/328' started by david bentley, May 11, 2010.
  1. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    #1 david bentley, May 11, 2010
  2. BigTex
    79,386
    Houston, Texas
    Bubba
    Where did the fishing line come from????
    Carefully measure the new rotor for compliance before installation, there's some 'long nose' ones out there, tearing up caps.....
  3. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    Well that sucks....
  4. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    How EVER could bugs get into the distributor?!?!!? :O
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    OK so when you cleaned it up did the misfire go away? I still can't understand how that stuff got in there.
  6. Rifledriver
    37,141
    It's strands of melted plastic from where the arcing burned through the plastic.
  7. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,280
    Seattle Area
    Dave
    I hope that's not your HAIR!! :eek: :eek:
    Jedi
  8. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Outstanding photography. Care to post details?
  9. BigTex
    79,386
    Houston, Texas
    Bubba
    It appeared that way.....the tip electrode looks pretty good, trouble at the center pin and /or spring.....
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Looks like an old rotor that was thrown into a camp fire for a bit then plucked out and tossed into an old wig and rolled around...
  11. rizzo308
    rizzo308 F1 Rookie
    2,782
    Perth, Australia
    riggio
    #11 rizzo308, May 12, 2010
    Ur lucky day, looks like you have the cheaper to buy version of the 308 rotor and not the big green/black chunky expensive rotors . Good luck
  12. mwr4440
    58,005
    Bavaria, The 'Other' Germany
    Mark W.R.
    R-E-A-L Question is:
    What caused THAT "Rotor Roast???????"
    I am not sure rotors do that of their own accord.
    Rifledriver ......... ?
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    That rotor looks pretty yellow, so I suppose it was in there for a pretty long time.
    I had one fail in exactly the same way, but it burnt much further, and thus made a lot of 'wool' within the distributor. Car wouldn't idle on that bank, but ran OK above 2000rpm, go figure.
    The replacement was very cheap and has been in there for 10.000kms now.
  14. afterburner
    afterburner F1 Rookie
    3,478
    Switzerland
    Urs STEMMLER
    #14 afterburner, May 12, 2010
    I had a new (150 mls after replacement) rotor short out from the center pick up through to the camshaft end, which led to that bank practically not producing any power. It took some time to find it as the new parts are not the ones you suspect of being faulty at first.
  15. Rifledriver
    37,141
    The insulating properties break down with time. Over the years they have made a few bad batches which did it very quickly. It got so that was the first place we looked when we lost ignition on an entire bank.
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Does this or can this happen to FI electronic ignition too?
  17. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    It was an interesting drive home. The misfire started 5 hours from home in the Gods middle of nowhere. It would run at between 3200 and 3700 rpm with light throttle. Above or below that I would loose the rear bank and the engine temp would drop...of course little power and very bad gas milage...but IT GOT ME HOME!!!!
    Dave
  18. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Photo of the rotor was made by "painting" with a flashlight...I am a professional photographer by trade now.
  19. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    New rotor cured the misfire
