Should Clutch Be Replaced | FerrariChat
Discussion in '348/355' started by jefflynch, Nov 6, 2010.
  1. jefflynch
    jefflynch Rookie
    Sep 6, 2010
    28
    Kansas City, MO
    Jeff Lynch
    So the engine is put back together, and it's going back in the car in the next couple of days. I pick up my first Ferrari ('97 F255) in Scottsdale later this week. I asked the technician to check the clutch and he said it's at 60%. Should I go ahead and replace it while the engine's out? Also, how much should I expect to pay for the parts? Thank you!
  2. Sandy Eggo
    Sandy Eggo F1 Rookie BANNED
    Jun 4, 2009
    3,636
    Encinitas, CA
    Rick
    Is it a F1 clutch or manual clutch? I wouldn't know what to tell you on the F1 but as for the manual clutch, I wouldn't replace it so long as:
    -- you have even wear across the clutch disc and pressure plate
    -- no hot spots
    -- flywheel looks true
    -- no evidence of clutch fluid leaking
    Some guys will tell you to go ahead and replace the teflon triple seals if you've gone as far as taking it all apart already. Up to you.
    A new clutch disc will run you $360 or so plus shipping. The entire clutch pack (disc plus pressure plate/housing) will set you back around $1,000. Ask me how I know. ;)
  3. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    i would just add if no oil either I wouldnt do triple seals.
  4. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Are you assuming that a brand new OEM flywheel disc is machined prefectly flat?
  5. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
  6. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    The one pictured on the right(one with hacksaw blade)...is that a new one from the factory(Ferrari) or is it one of those supposedly new ones that you exchange over there in the UK?
    The ones I have which are OEM factory complete assemblies are not machined perfectly flat.
  7. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Genuine Ferrari, not genuine flat but not far off.
  8. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Thanks Andrew.
    The slight off 90 deg is purpose design from OEM.
