Should I Change My Belts Or Just Forget It Until They Brake? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Dr Tommy Cosgrove, Sep 18, 2007.
  1. Dr Tommy Cosgrove
    36,659
    Birmingham, AL
    Tommy
    I am done with adjusting the valves. The last two times I did them they were all in spec. The first was in 97 at about 60,000 and then again in 04 at about 80,000. Both times nothing needed to be changed.
    I think I am going to swap the belts/tensioners sometime in the near future and just go from there. Everything else about the car is perfect. From here on out it's going to be simply fresh fluids and filters (all of them) by me as usual according to my extra-frequent interval schedule (which is extra-extra frequent during the track season) and start a nice little money market account for my dream rebuild. I figure by the winter of 08 I'll be starting to make phone calls. I am leaning towards Norwood out in TX.
    My plan:
    Port/polish with new upgraded everything on the top and at least 200cc larger on the bottom with increase in compression like the euro cars. Everything balanced. Honestly I want to stay with the K-Jetronic. If I did anything with the ignition it would be the electromotive route but I am still on the fence even with that. I want simple as possible, just a little more raw umph and that's it. Crazy complicated I can do without. I want to go 200K the next time around.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,633
    The Brickyard
    The Bad Guy
    You are "muy loco" Tommy, but I LOVE IT!!!!!
    You know we all wanna see if the belts will give in and when. You're a crazy boy. I'm not saying you should do it but..........................I'll be watching just in case.:D
  3. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    As a disinterested spectator, I'd say 7 years with new belts and tensioners and no leaks on them on a frequently driven, but not raced car, is worth the gamble. But I have a Lotus with a timing chain so feel free to ignore me. 3 majors in 7 years almost pays for a new motor anyway although YMMV.
    Ken
  4. ernie
    Nov 19, 2001
    22,633
    The Brickyard
    The Bad Guy
    Isn't that the truth.
  5. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    #30 FERRARI-TECH, Sep 19, 2007
    1980 308i
    2k miles in 5 years, look at the play in that belt, and although its not a great shot, half the diameter is missing as well.
    Its not a case of right or wrong, to me its more like " why should i carry car insurance, i am not going to have an accident"
    When they go, you will do more than damage a head!!. Get ready for pistons, block/liners/crank....... should i go on??.
    Change them yourself. Lock the cams, mark them, put the new belts on make sure the marks line up and fire away. Not rocket science.
  6. Bradley
    Bradley F1 Rookie
    Nov 23, 2006
    2,831
    Lakewood, Colorado
    Bradley
    The whole trouble with experimenting is that it has the potential to get very expensive.
    I would replace the belts next year, even if you're only keeping elephants off the lawn. Better to be safe than sorry.
    As for performance modifications, the QV performs very well without them. I do recommend HyperFlow cats very highly, but any other mods are going to necessitate more maintenance - including more frequent belt changes - and it sounds like money is, in fact, an object.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
  8. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,881
    Fusion Sports Ferrari-Tech,
    Thank you for the photo. However, I draw the opposite conclusion. I believe that your experience supports, if not justifies leaving the belts alone. I posit that if your belts failed in that way at 5,000 miles (2 years) that you installed a manufacturer defect.
    Belts that have traveled 30,000 miles have "...withstood the test of time...," and have demonstrated themselves to be "properly manufactured" and will likely sustain many more miles (vis-a-vis Honda, Toyota and the like-100,000 miles). Lurking in the background every time one "electively" changes a part is the fear that one is replacing a known good part with an unknown manufactured flaw. The same might be said for electively changing sodium valves that have traveled many miles with new valves. (While not wanting to change the subject, sodium valves fail because of a flawed weld, not because of metal fatique.)
    While belt failures do ocurr, the frequency, I believe, is somewhat amplified on the chat. This is a frequent and heated discussion in the flat-12 section (Boxers and Testarossas) where engines are quite a bit more expensive, and where it is much more costly to change belts. There is, clearly, a sampling error as several fine mechanics participate on F-Chat. They see the consequences of belt failure and report them on F-Chat. However, all of us not experiencing belt failure don't report (everyday) when our belts don't fail.... There were somewhere around 7,000 (or more) Testarossas and 3000+ Boxers produced across the series. If low mileage belt failure were a systemic problem I believe we would hear about it much more frequently. I do not believe that everyone owning flat-12s or 3x8s is compulsive about rushing in to their local Ferrari mechanic to plop down thousands of dollars at the turn of the odometer. Hence, old belts are still running around. I changed my Boxer belts after 20 years and my Testarossa belts after 17 years, both with 30,000 miles, and both could not be distinguished from the new belts taken off the shelf.
    Ken is correct. Following Ferrari's recommended service is not in the best economic interest of the owner. You can purchase a new engine after 3 belt changes.
    Jim S.
  9. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Tommy,
    I don't normally weigh in on this sort of thing but I think it is a bad idea to run until the belt breaks. When that belt breaks, the forces in the engine can be very strong. If a valve comes in direct contact with a piston, the cam to valve surface, the cam itself, the cam bearing, piston surface, the bearing under the piston, the piston to crankshaft bearing, the piston rod, the crank itself (balanced nicely before impact), the main bearing to the housing, the piston sleeve, the block....just to name a few,....get slammed pretty hard because they are ALL in the chain. I would worry not about what you know but what you don't. This will only give people a data point of one...not statistically significant...and the debate will continue to rage. Change the belts when you think they are due. IMHO.
    -Rjay
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,849
    The twilight zone
    A couple things to think about. The easiest way to make it 200cc larger is to just star with a 328 engine. I'm told a 360 crank can be had for about $100 will make a 3.2 abot a 3.4, I haven't done the math for a 3.0 base.
    The easiest way to get 30 hp is to scrap the CIS. It's a really up hill battle to make hp if you leave the CIS on the car with boost being by far the most effective. You could also do carbs if EFI scares you....but EFI isn't that scary really
    I think Norwood is probably a good choice to build the engine, I may use them too for the machine work at least on my new project, but they don't do porting as far as I know. They may be able to recommend someone good because all porting is nothing like the same. If you were closer to ready to go, I'd offer you my QV heads that I no longer will be needing. Oh, the CIS intake manifold is also a problem for flow, so as soon as you touch the heads, the problem moves to the intake and I’m not sure how much can be done to fix the intake, the runners are much too small, but I’m sure it can at least be improved.
  11. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    My cars are all helicopters. I do not tolerate breakdowns. Things that go most often are usually the least expensive to replace. These include batteries, brakes, hoses, belts (in most cars) and tires. I buy batteries that are 3 or 4 year free replacement and replace them after 3 1/2 - 4 years. I trickle charge them for 24 - 48 hours every other month just to keep them topped for example. I buy the parts as the time is approaching then leisurely do the work at my convenience. I can sometimes take advantage of sale pricing this way.
    aehaas
  12. Ferrari Rare Parts
    Ferrari Rare Parts Formula Junior
    442
    Rome Italy
    Orlando
    you are joking I hope! Imagine racing on a highway and you bend a valve or engine seizes you lose control of your vehicle being scared of the loud bang of a piston going through!
    That is dangerous! For also your passenger and other drivers!
    Ferraris are for people which do not have problems spending money to keep them in shape!
    After doing years of scarifices to own one ,lets go out and break one! No you don't love your Ferrari!
    Belts cost $190 including bearings,if you changed bearings last time you can change belts only.But its $190 towards a car which is worth $30000-$40000.
    You can change the belts yourself as another Fchat member said you don't need to be a rocket scientist!
    Instead of building a stronger unoriginal engine buy a 328!
    Ferraris should be left how they were from the factory,I agree if you like to personalise wheels or carbon details ,but If you like a 308 it has to be a 308! Not a 308 with an F40 engine!
    I find it funny seeing people placing corvett engines in Ferrraris!
    Hope you do your car a favour and change its belts.You'll proberly do your bank account a favour also!
    Save and get a 355 if you want power or break and keep the 308 !
  13. Dr Tommy Cosgrove
    36,659
    Birmingham, AL
    Tommy
    I decided I was going to go head and change my belts by post #7 yesterday morning. Don't worry guys this theoretical experiment isn't going to happen.
  14. Ferrari Rare Parts
    442
    Rome Italy
    Orlando
    GREAT DO YOUR SHOPPING IN THE STATES ,I SELL FOR $190 ORIGINAL BELTS & TENSIONER BEARINGS, OTHER ITEMS CONTACT ME AT [email protected] see whats cheaper for you and decide.
  15. Dr Tommy Cosgrove
    36,659
    Birmingham, AL
    Tommy
    I agree with you about buying the etc. that is the logical course. However I want to keep my 308 and I am a 308 lover to the first order. I simply want to improve what I have when the time comes and keep it as uncomplicated when it's over as possible. Forget the big block Chevy crap, I want my Ferrari V8 with a little extra where we can. Displacement, compression and intake/exhaust improvements are what I am interested in. Small improvements in those areas will give me the results I want and the maintain the simplicity, dependability and durability that I already have. What I DO NOT want AT ALL is a car that you have to keep your foot on the gas at a stoplight because of the cams and a laptop to set the timing. I want no part of any of that. None. I have done this with other cars in the past. Some I liked some I hated. Besides I have a driveway full of sports cars now including a VW that will run circles around a stock 328 all day at any speed below 90. I can satisfy my crazy bolt on cravings elsewhere. I don't have to use my 308 for that.
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    Tommy, I think I'm doing it now, My belt has seven years and 7,600 mile on it and I'm still driving it weekly, I know I'm insane for taking a big chance, but SOON I mean SOON I will change it myself and keep you guys inform.
  17. SonomaRik
    SonomaRik F1 Veteran
    that's what I was having problems with in your first set of posts, that you want to keep and cherish this car, yet string out the maintenance on the one part that would make that desire a bit null and void.
    Tell me [honest question here]: Did you have a certain change in heart due to risks or differing logic in changing belts? Why the change.
  18. butch355
    butch355 Karting
    Jan 27, 2005
    114
    Denver
    Brent
    I did my first 30k service on my 355 at 7 year mark with Dave Helms in Boulder back in 2004 car had 13k miles on it. When it was taken off he said "this belt still look good!". The car had a whole host of other things needing fixing, my point is that the belt was not he weak point of the car at all!
    I agree with the past posts about a belt being made to last 7 years with normal driving. If you drive at 8k rpm all the time or track, well then that changes everything. Typical cars dont do that RPM or have the heat of the F cars.
  19. Dr Tommy Cosgrove
    36,659
    Birmingham, AL
    Tommy
    I simply thought that if I am going to tear the engine down and rebuild it anyway in the next few years why spend the money on the belt change next Mar? The car has 100,000 miles on it. If it breaks, I rebuild the engine. If they don't break I will rebuild the engine. Either-Or...
    I changed my mind when I found out that I could possibly DESTROY the engine - as in not have a rebuildable core. That's why I was asking you guys first.
  20. BigTex
    79,418
    Houston, Texas
    Bubba
    That's really it in a nutshell...too much can happen.....up to and including shattered pistons and thrown rods....
    The same thing can happen with a sodium valve breaking, so do them too.
    Good Luck Dr.T.!
  21. SonomaRik
    and
    so, not bad to run it up the flag pole and see who salutes....your logic did have some value and was interesting to explore....
    [now ... any great ideas on valve guide replacments ;) ]
  22. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    I did not install those belts, so cannot comment intelligently about there origin or set up, I am just changing them now.
    The owner gave the old " But I have not driven that many miles, why change them", Until I had him come by and see the belts.
    I recommend 3 years, will allow five, but go seven and tow your car out of here.
    I tell people all the time, Ferrari ownership is not for everyone.
  23. martinp
    martinp Karting
    Jan 11, 2005
    69
    Nr Ludlow, Shrops UK
    Martin Phillips
    The consequences of a belt break are horrific.
    Just to put a bit of perspective on this though,
    According to the dealer, Ford's current policy in the UK for their "Focus" model (4 cyl 1.8L) is to change the cambelt after 10 (ten) yrs. That's typically 100k+ miles
    I'm afraid that my Ferrari won't be doing anything like that before a belt change, after all I could buy a couple of new Ford Focus's for the price of a replacement engine.
    Martin
  24. Dr Tommy Cosgrove
    36,659
    Birmingham, AL
    Tommy
    If Rifledriver were still around I would have been torn to shreads by now
  25. Wolfgang5150
    Wolfgang5150 F1 Rookie
    Oct 31, 2003
    4,706
    Tommy - always remember The Law. .....The Law of Unintended Consequences. There are way too meany negative variables here to make this seem as easy as it is. ie' they break when you are on the freeway, and you innciently get clobbered by a car like the guy in Florida with his Boxer'.....I could go on and on.........
    Why not just take a pile of money and set it on fire in your yard?
    If you have always wanted this car since 1981 - why destory it to try and upgrade it?
    Just my 2 cents (or 1/2 a peeny against worldwide currency)
    Kevin S.
    Orchard Park, NY
