Should I worry? | Page 2 | FerrariChat
Should I worry?
Discussion in '348/355' started by Ben348, Jun 5, 2013.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    Well, if he has done it for 20 years, does not need to write anything down because he has photographic memory, has all the right tools in place, knows all the short cuts, and the car is in such good shape that none of the studs break or the nuts frozen in place, then well, maybe in 2 hours. Hell, it took me 20 minutes alone to clean up the coolant mess because I did not want to slip on that slippery stuff and kill myself. It is for this very reason that the very smart Dave Helms invented the block drain device.
    Pap, let me give you a hint toward your 2 hour goal: Devise a way to plug up the brake and clutch lines. Not with a plastic bag, and a rubber band. Otherwise, you will end up with a big mess and a very tough time bleeding your master cylinder.
  2. stevew
    stevew Formula 3
    Jun 9, 2002
    1,839
    uk
    Steve
    You've got to be kidding
  3. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Wow! 2 hours to drop the engine I am betting you didn't mean that seriously and yes I have done my own engine out. Unless of course the 348 is much easier than my 355.
  4. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Don't worry mate, before I attempt it I will have all the tools laid out next to me so I don't go searching (after 17 years in the trade you know how to tell the size spanner/socket you need just by looking at the head of the bolt) will have everything in place to make it as easy for me as possible and I always devise a plan of attack before I start any job I have never done before.
    We both know I won't do it in 2 hrs being my first time, but I will give it a red hot go. :D
  5. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    6.5 hours. Something bent. Something spilled. Something cut. Something busted. :D
  6. Ben348
    Ben348 Formula Junior
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    Okayokayokay, I'll do an engine-out...
    And while I am doing it, I can adress the noisy gearbox or tranny.
    Any how-to's on rebuilding the gearbox? In the last 5 years it has gradualy build up a gentle whine in 4th & 5th..
    Is the gearbox rebuild doable or should I send it out to god-knows-who?
    Happy wrenching!
    Ben
  7. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    Good choice!
    Do-able.
  8. Ben348
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    Good to hear! Know any how-to's? Diy?
    Thanx. Ben.
  9. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    Do the belt guide rest on the belt or is there supposed to be a clearance. I didn't recall seeing anything in the service manual regarding them?
  10. Ben348
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    Dave,
    The guides are not on the belt. Aprox 8 mm gap between them.
    Regards. Ben
  11. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Lol. :D:D
  12. Ben348
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    #37 Ben348, Jun 12, 2013
    Okay, it took me 2 hours to Jack her up and put the stands on the right spots.
    Every time I work on the 348 I end up cleaning and polishing al the aluminium parts....
    Anyways, after removing the underpannels, I noticed the airco compresser being loose. The spanner was hanging by a threat, causing the belt to be totaly wobbely.
    Therefor I think I have found my screamer.
    Ofcourse the marks on the other belt are under investigation...
    Regards. Ben.
  13. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Now you found two issues that need to be resolved, nice to kill 2 birds with 1 stone :)
  14. Ben348
    Jan 1, 2008
    304
    NH the Netherlands
    Ben
    Dkny,
    Sorry, it is more like 2mm...
    Regards Ben.
  15. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    Thanks,
    I think I better check it
  16. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Any update to the Mystery of the Mangled Belt?
