Should the engine be warmed up in the morning? | FerrariChat
Discussion in 'California/Portofino/Roma' started by aazizkhalid, Sep 2, 2012.
  1. aazizkhalid
    aazizkhalid Karting
    Aug 4, 2012
    72
    DUBAI UAE
    I had been starting the Cali and just driving straight away, only at lower revs until the temp went up to about 70... Recently someone told me that I must properly warmup up engine before driving in the mornings... I.e. start the car and leave it to idle for a few minutes until temprature gets to the desired level..
    What do you guys do? And anyone ever damaged engine by not properly wArming up their engine?
  2. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    Never warmed it up even in very cold weather. Like you, I just drive gently for a few miles. Was always taught (learned to drive in Canada) never to warm up the engine, just start and drive gently (I kept my Cali under 4000 rpm for the first 5 mins of driving) until it gets up to operating temp. I was told that it's just not a good idea to let an engine warm under no-load conditions (there was a reason for this that i have now forgotten...it was too long ago!). One thing I do know, it takes much much longer to warm up if it's just idling.
  3. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    +1. Use auto mode to keep revs down until at least water temp comes up.
  4. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Also in these dry sump engines, there is so much oil in the system that it takes longer for the oil to reach operating temp than for the coolant. Since oil flow properties vary with temp, you really want to get oil temp up before "exercising" the engine.
  5. hotbmwm3
    hotbmwm3 Formula Junior
    Jan 11, 2006
    554
    Melbourne and London
    Owner -09 California
    California has a wet sump unfortunately
  6. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Ah... I didn't know that. Wonder why.
  7. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,841
    Due to the fact that the Cali has a wet sump, the oil temp rises to operating temperature a lot quicker than dry sump systems.
    I think this is a nice advantage for the Cali. I drive to work and appreciate this time savings in the morning. If I had to drive my 360, it would take 10 minutes before the oil temp started to move on a cold morning.
    As far as oil starvation when pulling high g's in a corner, modern wet sumps perform much better than older wet sump systems in this area.
    I don't think Cali owners have any worries if they track their cars about burning pistons or cranks.
  8. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    +1
  9. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    Indeed... BUT with almost the same oil capacity as dry sumps :D.
  10. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    Start it and drive it. I keep it below 3K until I see water temp or movement then careful until it gets to normal operating temp, about 2.5 miles.
    Rick
  11. jjmcd
    jjmcd Formula Junior
    Dec 3, 2004
    490
    The owners' manual of my air cooled Porsche 911 (which takes 12 quarts of oil) specifically says that you should warm the car up by driving gently, rather than letting it idle, because idling does not evenly warm up all of the parts of the drivetrain. I have followed this practice over the 13 years that I've owned the car and accelerate gently and limit the car to 3,500 rpm until it warms up, with no apparently damage to the engine.
  12. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    It is illegal to idle with your car running for more than 5 minutes here. You can only warm up your car longer than that if you want to break the law. So you just have to drive it.
    Suggestion: do not take the engine over 4k until the oil is warm...the gauge will start to move.
  13. not4one
    May 23, 2010
    887
    CT, FL
    Do you have to stay under the speed limit too?
  14. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,836
    Richmond
    Pete
    My BMW manual also specifically states not to let the car sit and warm up. The explanation given is that it takes longer to warm up and consequently there are more acid by products produced when the engine is cold that contaminate the oil and cause wear on aluminum engine parts. I always drive my Fcar below 3000rpm until water temp comes up and below 4000rpm until oil temp comes up.
