360 - Shout out to RC Fuel Injection! No more cold-start stumbles! | FerrariChat
360 Shout out to RC Fuel Injection! No more cold-start stumbles!
Discussion in '360/430' started by Jaymac, Sep 24, 2025 at 6:43 PM.
  1. Jaymac
    Jaymac Formula Junior
    999
    New Hampshire
    Jeremy McCurdy
    Just wanted to give a huge shout-out to RC Fuel Injection in Torrance, CA. Many of you may have read or participated in my past threads about my intermittent, and then consistent, cold-start stumbles. After seeing and hearing many accounts of people fixing this by having their injectors cleaned or replaced, I decided to use RC to test/clean/rebuild my injectors.
    Wow!
    After the first start with fuel-starved rails and an ECU reset, it’s been 10 days of consistently perfect cold-starts. Flawless every time. The engine fires more quickly and with greater vigor. The midrange pull to redline is harder, faster and crisper. I couldn’t be happier.
    The report showed many injectors were leaking or clogged. I’ll attach the report below. This is a 2003 360 with 46,000 miles. I got it 4 years ago with 18,000 miles. I only use Shell 93, and a bottle of BG44K or Chevron Techron twice a year or more.
    The injector cleaning has been a game changer. Highly recommend to anyone who’s experiencing similar symptoms. 10/10!!
    jerbear27, imahorse and Qavion like this.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,095
    Central NJ
    Dominick
  3. Jaymac
    999
    New Hampshire
    Jeremy McCurdy
    You called it! Another Dominick win! And this wasn’t even an F1 issue!! :D
    Mel Spillman, Qavion and flash32 like this.
