Show us your fire extinguishers & position | FerrariChat
Discussion in '360/430' started by boba fett, Dec 6, 2021.
  1. boba fett
    boba fett Formula 3
    1,098
    England UK
    Hi all, I want to install a Fire extinguisher inside the cabin. Mine is currently loose in the front trunk.
    What extinguisher have you got, what size do you have, and where have you fitted it. I know some have installed them in front passenger seat which looks good, but I think I'd like mine in the gap in front of the gearbox. Anyone done this?
    How you fitted it would be handy to know as well Image Unavailable, Please Login
    Thanks in advance
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,110
    Josh @jtcarprojects
  3. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    906
    S La
    Mounted on the seat rails with a generic sort of bracket. Does not get in the way and easy to get to if the worst happens. Looks like the pass seat in the previous post is brand new or has never had a butt on it. I did not clean up the car before the pic and missed the best part. The stick! I have a few cars and the 360, my favorite, has to be the one going up in price like a rocket. Typical.
  4. BRIOSO
    BRIOSO Karting
    116
    The photos are in my 550 but I don't see why the Brey Krause bracket would not also fit your seat. this is a quick release, tucks away nicely and as you can see in the last photo, you really don't know it's there, yet it is right there should one need to grab it and exit the car in an emergency. It is attached to the seat, so it moves with the seat. I have more photos of the mounting hardware installed under the seat if you are interested.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  5. Mario Andretti
    Mario Andretti Formula 3
    1,774
    Boston
    Snapshift and Mimmo Blue like this.
  6. ItalGerBrit
    Mar 15, 2016
    906
    S La
    Yes. I have a couple of those in other cars. Small and easily tucked away. Forgot about them. Thanks for pointing them out.
    Snapshift likes this.
  7. Zack Hawker
    Zack Hawker Karting
    Feb 27, 2018
    132
    Paradise Valley, Az
    Zack Az Realtor
  8. Snapshift
    Snapshift Formula Junior
    923
    Centralia IL
    Lyle D. Pahnke
    I have the element fire extinguisher in the rear shelf pocket above the subwoofer box. It is not visible to passengers. A big red floor mounted fire extinguisher that I had prior was not a real confidence builder to prospective passengers, was somewhat intimidating, worrisome and confusing that this expensive car could catch on fire unexpectedly at any time.
    Mario Andretti likes this.
  9. CoreyNJ
    CoreyNJ Formula 3
    2,439
    New Jersey Shore
    colorfull and Penzinger like this.
  10. LorenzoR
    LorenzoR F1 Rookie
    I dont have pics but in my old car that i sold i just used some red velcro straps to hold it in place to the floor mat. It worked very good.
  11. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    Careful w velcro as it could go flying in an accident. I used the same bracket as post #2 after my velcro one let go on heavy braking.
  12. LorenzoR
    LorenzoR F1 Rookie
    I laid my extinguisher along the console just like that black one is sitting and never had an issue with it rolling. I used a heavy-duty Velcro. Now at first I tried putting the extinguisher against the seat bottom but that's when it rolled. So that's when I went to a heavier-duty velcro and put it against the console like the black one
  13. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I had mine like this before and then like I said it broke free during a hard brake.
    Switched to the generic eBay mount from #2 bolted to the seat rails.
  14. LorenzoR
    LorenzoR F1 Rookie
    Maybe you needed stronger velcro. I know the velcro i used is tough to pull apart. Anyway the fire ex is also on my list for my new to me car
  15. Flyingbrick242
    Flyingbrick242 Formula Junior
    674
    Northern AZ.
  16. boba fett
    boba fett Formula 3
    1,098
    England UK
    Keep them coming guys.
    love the carbon wrapped one. To be honest I am hoping I never have to use it, but they look very cool
  17. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    Saved my boat with one. Also had my passenger F430 puel pump start leaking. Good to have!
  18. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    Unless your car came with the extinguisher from the factory and your trying to keep your car all original, I don't understand why anyone would have a dry chemical fire extinguisher in their car. Have you actually ever used a fire extinguisher? The dry chemical can make more of a mess than the fire you are attempting to put out. If your really concerned about putting out a fire I would recommend the Element extinguisher as it lasts way longer and won't make a mess.
    Thomas S. likes this.
  19. CoreyNJ
    CoreyNJ Formula 3
    2,439
    New Jersey Shore
    Where did that come from? Every picture here I see some type of Halon or HalGuard extinguisher not some cheap Home Depot special dry chemical fire extinguisher. I know mine is a HalGuard and is designed to not leave a corrosive residue.
    As to why use a real extinguisher over an Element? Training. If the car catches on fire, I don't have to explain to my passenger or passerby who see it on how to use the extinguisher to save someones life. Screw the car. Let it burn, but Fire Extinguishers can save someone's life. To the un-trained, an Element looks like a road flare.
    Now do I think the Element is a good product, yes and it would be prudent to throw one also in the door pocket since they are so small and why not, but they are not a replacement for a real Fire Extinguisher because the general public doesn't know what to do with them.
    Sj_engr likes this.
  20. boba fett
    boba fett Formula 3
    1,098
    England UK
    I am going to get an Element to put in the side pocket, its a good product. however, a real fire extinguisher looks a lot better than having what looks like a tube of smarties on show.
    I have just bought a Lifeline AFFF jobbie, it looks very similar to the OEM one and has a similar bracket. I'll repaint it, apply a graphic and then lacquer so it looks factory and see how that turns out.
    I am surprised no one has gone for mounting under the stereo on top of the transmission tunnel? It looks like the obvious place to me and fills a gap that should have been filled!
  21. CoreyNJ
    CoreyNJ Formula 3
    2,439
    New Jersey Shore
    Are you going to drill into the floor? My bracket I made was a copy of the RaceSafe which attaches to one side of the seat rail, is completely removable and doesn't modify the car. To be honest if I didn't already have the extinguisher from when I had the bracketeer I would have just bought the complete RaceSafe unit with bracket. Buying the bracket alone is expensive.
  22. boba fett
    boba fett Formula 3
    1,098
    England UK
    I am going to look into, may even self tap or rivet, I'll consult my Technician for whats best to do if I go for it.
    Think it will look awesome there.
  23. Silber
    Silber Karting
    Jun 6, 2014
    119
    Switzerland
    I've got something that reads similar to the Element (similar to https://firesafetystick.com/) in my door pocket. Far preferable to one of these huge things in the footwell that'll unlikely be used anyway, and probably more accessible.
    LorenzoR and EastMemphis like this.
  24. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    I've had an Element extinguisher in my door pocket for years now.
    You can wrap it in a microfiber towel to stop it from moving around and making noise in there.
  25. Mr. Uy
    Mr. Uy Formula Junior
    334
    Fort Worth, TX
    Charlie U
