News
Show us your overhead liner Targa top, please?
Discussion in '308/328' started by 11506apollo, Nov 23, 2009.
  1. 11506apollo
    11506apollo Formula 3
    2,017
    I am tired of my liner, so I will be doing something about it. If I will try and maintain it close to OEM look or not depends upon many factors. The cloth is sagging and it is stained (by p.o.) so it is the weak spot on my otherwise pristine 308.
    Please post pics of your headliner and a brief explanation of did you do to it. I am looking for ideas.
    Thanks!
  3. JV's89
    JV's89 F1 Rookie
    Rossa Subscribed Owner
    Jul 18, 2006
    4,577
    Pittsburgh, PA
  4. rizzo308
    rizzo308 Formula 3
    2,227
    Perth, Australia
    riggio
    #3 rizzo308, Nov 23, 2009
    1982 308 hood lining is the cream/white honeycombe type my mate bought some from USA 4 yrs ago 1.5 mts of cloth cost him $1500 landed in here in ozz i tried for months to find it i was told its NLA so i hunted down some cloth it's not exactly the same buts it's the best i could find and hell of a lot cheaper if you get stuck i can get some for you .....cheers
  5. 11506apollo
    2,017
    How did you apply/installed the new cloth? Sprayed glue? What type?
    What about the rubber gasket? Re utilized the old one, or replaced?
    Thanks.
  6. rizzo308
    rizzo308 Formula 3
    2,227
    Perth, Australia
    riggio
    my car is GTB it has a fibreglass shell which comes out and the lining is glued to it
  8. Lorenzini
    Lorenzini Karting
    Sep 3, 2008
    85
    Granite Bay, CA
    Kenneth D. Lawrence
    Mine too was sagging and abit stained, so I removed it and scraped/washed off all the old foim rubber that was deterioating. I saoked the headliner fabric in woolite and let it sit for a while and then just rinsed with a water hose, came out clean and not distorted. The side seals will need to be replaced as thy are very much attached to the headliner, take measurement as to ther placement, although the residue of the rubber seal will still be imprinted on the fabric, use a cotton fabric/heat shiel material to replace the old foam and it look as good as new. good luck
  9. dave80gtsi
    dave80gtsi Formula 3
    1,491
    Ohio
    Dave Meredith
    I removed all of the old dirty / smelly / stained cloth and replaced with a creme leather. Same for the back deck area behind the seats, below the rear window
    Looks better, cleans up nicely, and smells great!
    I will try to find a picture if there's enough interest, but it pretty much looks like you would already expect it to look.
    Cheers - DM
  10. BigTex
    Dec 6, 2002
    74,279
    Houston, Texas
    Bubba
    Claudio is working on his GTS....which uses the rare fabric material on the targa roof and rear shelf...
    Did you check ReOriginals, Claudio???
    I know, as others post, it's pretty hard to find.....
  11. VeloceSpace
    VeloceSpace Rookie
    Sep 4, 2009
    20
    The cream/white material is NLA. The only one left is the brown/cream stripe fabric that came on later cars, and even this is tough to re-make. There's another thread on this elsewhere in this forum: keyword "headliner".
    We had 5 meters last week, now we only have 2.5 meters, enough for one car. Please contact us if interested: info@velocespace.com
  13. kerrari
    kerrari F1 World Champ
    16,529
    Coolum Beach, AUSTRALIA
    Karen H.
    #10 kerrari, Nov 26, 2009
    Here's a pic of mine which is quite different from anything mentioned so far - cream vinyl with black trim? My car was an 'orphan' before I got it so I have no idea where this comes from, but actually the vinyl is quite practical as it cleans easily. The cream bits are very slightly padded, each panel apparently glued to the main roof panel. GTS 1980 on the paperwork, but I suspect might truly be a '79 car (29041 s/n, carb's).
  14. bobs308
    bobs308 Karting
    Dec 4, 2007
    111
    Lubbock, TX
    Randy Edwards
    The panel in my 1978 is identical to your picture. Randy
  15. BigTex
    Dec 6, 2002
    74,279
    Houston, Texas
    Bubba
    Happy Thanksgiving, Karen....
    That looks like the early '78, '79 GTS lids used the same cream vinyl of the GTBs roof liner.
    It would hold up better.
    All my cars have black vinyl rear shelves, that would match the insert strips.
    The cloth treatment started later???
  16. kerrari
    16,529
    Karen H.
    Same to you Big Tex - we don't actually have "Thanksgiving" over here, but thanks all the same! Looks like my lid (along with a lot of other bits!) were scrounged for this car. There's no cloth at all in my car - all black leather / vinyl.
