Show Your Boat | Page 21 | FerrariChat
Show Your Boat
Discussion in 'Motorcycles & Boats' started by 4RE886, Mar 20, 2009.
  1. koisokok
    koisokok F1 World Champ
    12,470
    nine 0 two one 0
    #501 koisokok, Jan 8, 2011
  2. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    #502 enginefxr, Jan 14, 2011
    Two Fountains I maintain for a customer. Why he has two of them, I'll never know!
    First one is a 47' Lightening with 3 x 900 hp supercharged 541 cu in engines with Mercury #6 drives. (That's me in the white shirt going on a water test after rebuilding the engines)
    The other is a 42' Lightning 2 x 575 hp fuel injected/supercharged 502 cu in with Bravo 1 drives.
    Mercury Racing recommends freshening the heads every 100 hours and rebuilding the bottom end every 200 hours....and you guys thought Ferrari's had a bad reputation for maintenance. :D
  3. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,205
    Huntsville, AL., USA
    Andrew
    That's a nice looking boat. :)
    Are boat engines much different from car engines? :confused:
    All the best,
    Andrew.
  4. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    In a word, absoulutey!! Boat engines run at high power for a high percentage of time. In a car an engine runs at high power for a few seconds and then cools back off. In a boat high power can be run for hours on end. Material stress rupture life is a big function of temperature for things like exhaust valves. We figure as a rule of thumb, a 25 degree hotter temperaure in a part like that cuts the life in half. Run an exhaust valve 100 degrees hotter and the life is 1/16 of what it was before. Easy to see how exhaust valve life in a car engine is in the thousands of hours, as noted above you do the heads in a high performance boat every hundred hours and the parts are a lot more expensive because of the higher material requirements. Boat engines are a lot more like airplane engines in terms of duty cycle and the costs of building an engine for that kind of service are a lot higher than a car engine. You can marinize a car engine for light duty work, like in a ski boat, but that's a lot different than a high speed power boat like this....
    About how much do you figure for for engine maintenance on a per engine, per hour basis, and how many hours per year do you generally figure for usage? I knew the life was short, but I didn't realize that these engines had that short a time between overhauls, but if you do drop a valve it trashes the engine and the cost of that is huge too. Just curious as to how the people involved see it.
  5. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    I know Mercury Racing charges around 26k per engine to freshen them up, IF the owner sends them there. An engine freshen for me (depending on exactly what the engine is) is roughly 3500.00 plus parts and R&R labor. The R&R labor is pretty intensive, especially if the drives have to come off, or if the boat has triples- not much room between them. I would figure the #6 drives weigh around 500 lbs each.
    The 47' boat came to me with no compression on one bank of the RH motor. Burnt two pistons, and torched the block and head about 1/4" deep between those two cylinders. The boat had 109 hours on it. So pulling the heads off at 100 hours as recommended may have saved it. All the head gaskets on all 3 engines were burnt or almost ready to burn through.
  6. 4RE886
    4RE886 Formula 3
    Feb 10, 2009
    1,184
    California
    Bob
    Beautiful boat!
  7. Sea-Dated
    Sea-Dated Formula Junior
    632
    Tulsa, OK
    Matt
  8. Sea-Dated
    632
    Tulsa, OK
    Matt
    #508 Sea-Dated, Mar 3, 2011
  9. 4RE886
    4RE886 Formula 3
    Feb 10, 2009
    1,184
    California
    Bob
    Nice! How fast is she?
  10. Sea-Dated
    632
    Tulsa, OK
    Matt
    Thank You
    Tops out right above 70 in salt, 68-69 in fresh water.
    Fast enough for me.....
  11. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,205
    Andrew
    That's interesting. Is there any particular reason that boats are ever-so-slightly faster in salt water than fresh water?
    All the best,
    Andrew.
  12. Willybeen
    Willybeen Karting
    Aug 18, 2009
    238
    Vero/Palm Beach
    William
    perhaps more positive buoyancy?
  13. TimsBlack16M
    TimsBlack16M Formula 3
    Jan 27, 2005
    1,365
    Agoura Hills, CA
    Tim
    Boats are slightly faster in salt water due to having a higher draft. The increased buoyancy of salt water will make the boat float a little higher (higher draft), resulting in less "drag" underway. The affect on speed is minimal, but none-the-less exists.
    Tim
  14. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,205
    Andrew
    Thanks guys. :)
    All the best,
    Andrew.
  15. Sea-Dated
    632
    Tulsa, OK
    Matt
    Exactly. Well said gentlemen. Most performance boats will pick up between 2-5mph in the salt water.
  16. Bronzage
    Bronzage Formula 3
    Sep 18, 2007
    1,129
    West Africa
    MJ
    #516 Bronzage, Mar 30, 2011
  17. Willybeen
    Willybeen Karting
    Aug 18, 2009
    238
    Vero/Palm Beach
    William
    ^where was that taken.
    I love that boat, looks deceivingly small in that picture.
  18. Bronzage
    Bronzage Formula 3
    Sep 18, 2007
    1,129
    West Africa
    MJ
    #518 Bronzage, Apr 1, 2011
  19. BigTex
    79,407
    Houston, Texas
    Bubba
    Note those twin screw blowers on the top Andrew....yea, they are different!
    Zul starts out with 800 - 100 horsepower and goes UP from there!
  20. BigTex
    79,407
    Houston, Texas
    Bubba
    Salt water floats them higher, slightly better bouyancy = lower drag/wetted surface.
  21. BigTex
    79,407
    Houston, Texas
    Bubba
    That's cool!
    Enjoy!!!
  22. darth550
    Jul 14, 2003
    61,193
    In front of you
    BCHC
  23. MaxPower
    MaxPower Two Time F1 World Champ
    Mar 28, 2006
    20,786
    At sea ... aahhh ...
    MP
    beautiful mate ...
  24. ronin exige
    ronin exige Karting
    Jun 9, 2011
    151
    #524 ronin exige, Jul 1, 2011
    Hi guys I have no Ferrari at this time but I have had a few over the years and sold them awhile back when I bought this to go crusing in 96. I still have it and will be out this weekend since it's gonna be too hot to cruise the canyons in my little rocket pig...
    Custom built Rob Ladd design 61 ft with a 8 ft draft wing keel. I've rigged it for single handed sailing and have punched through swells at 14.8 knts reaching...
    TUTTSF and Laserblue like this.
  25. ronin exige
    ronin exige Karting
    Jun 9, 2011
    151
    #525 ronin exige, Jul 1, 2011
    Laserblue likes this.
