News
showroom - Ferrari 250 Testa Rossa -
Discussion in 'Vintage (thru 365 GTC4)' started by 250bizza, Oct 21, 2008.
  1. 250bizza
    250bizza Rookie
    Aug 12, 2008
    11
    #1 250bizza, Oct 21, 2008
  2. Fpayntr
    Fpayntr Karting
    144
    Where is this place?
  3. Marcel Massini
    Marcel Massini F1 World Champ
    Honorary
    Mar 2, 2005
    13,158
    REPLICA. And LHD.
    Marcel Massini
  4. drakefan
    drakefan Rookie
    26
    Hi, based onto what kind of documentations / chassis etc, are you assuming this is a replica?
    I dont' think so. I asked to the guy owner of the car and I know the story...
  5. Marcel Massini
    Honorary
    Mar 2, 2005
    13,158
    Door style, dashboard, instruments, steering wheel, steering wheel position, plus many other details. A replica for sure.
    Oh, btw, FILL IN your profile.......
    Marcel Massini
    mcimino likes this.
  6. El Wayne
    El Wayne Global Moderator
    Global Moderator Owner
    Aug 1, 2002
    17,953
    San Marino, CA
    L. Wayne Ausbrooks
    Looks like he's been banned already.
  7. T308
    T308 Formula 3
    1,000
    Southern Cal
    The OP has. Drakefan's still here.
  8. emcrx
    emcrx Rookie
    Apr 21, 2008
    27
    Clermont, Fl.
    Edgar M.
    #8 emcrx, Oct 22, 2008
    See below pictures, compare and listen to the experts (Marcel Massini, Napolis, El Wayne and others...). I'm an exotic car enthusiast and I have a good knowledge (I think) in Ferraris but not like these guys. em
  9. bigodino
    bigodino F1 World Champ
    10,894
    The Netherlands
    Peter den Biggelaar
    Hi Marcel,
    Aren't most pontoon fendered LHD? BTW is this the (ex?) Heuberger replica based on a Boano?
    Best regards, Peter
  10. Boudewijn
    Boudewijn Moderator
    Moderator
    May 15, 2003
    4,106
    The Netherlands
    Boudewijn Berkhoff
    I believe that one is RHD Peter.
  11. kare
    kare F1 Rookie
    Nov 11, 2003
    3,227
    No, that one is RHD (pretty strange!). It's not the worst TR replica around, the size and shape of the door distrubs me most. Instruments and steering wheels come and go; they are sometimes wrong on real cars too. Best wishes, Kare
  12. michael platzer
    michael platzer F1 Veteran
    Nov 12, 2003
    5,181
    Austria
    Michael Platzer
    only 0666TR and 0746TR are RHD.
  13. michael platzer
    Nov 12, 2003
    5,181
    Austria
    Michael Platzer
    correct - the replica based on the boano 0611GT is RHD.
  14. drakefan
    drakefan Rookie
    26
    Hi,
    the steering wheel is an original one! it isnt' a replica such as many Nardi coming from a new production by the Nardi - professional near by Varese - Italy...or some steering wheel wellproduced in few quantity by " artisan " in those last year...
  15. rcm360
    rcm360 Formula Junior
    Nov 16, 2003
    330
    Kansas
    Reese
    It was on Ebay last week and I am sure there is a link in the Vintage Section, I would look but busy day today
  16. 400iGuy
    400iGuy Formula Junior
    Rossa Subscribed Owner
    Aug 26, 2004
    979
    Central Florida
    Al
    What is the story?
  17. drakefan
    drakefan Rookie
    26
    Hi, the owner of the 250TR knows Marcel Massini...he asked me not to give infos about his own car because he was very disappointed about such declaration by Marcel ...who is a specialist and who should be careful in any kind of declaration about Ferraris. We are sure that he knows very well Ferrari 250TR! not many 250 TR have been constructed by Ferrari! I respect the owner of this 250TR...
  18. tomgt
    tomgt F1 Veteran
    6,056
    Netherlands
    Tom Wiggers
    s/n please!
  19. Motob
    Motob Formula 3
    Nov 11, 2003
    2,143
    Berkeley, CA
    Brian Brown
    #19 Motob, Oct 26, 2008
    Maybe the owner should have consulted Marcel Massini before he bought this obvious replica.
    Here are just some of the things that are incorrect: Tachometer incorrect. Gauge mounting is incorrect (should have four screws in a pattern around the tachometer, switches in gauge cluster are incorrect, ignition switch is incorrect type (early type with headlight switch, should be later style with push key to start),
    The shape of the dash is wrong, it should taper to the right of the ignition switch, it has a sharp corner. The brake and clutch pedal are incorrect, The should be oval with a wooden pad. The location of the throttle pedal is incorrect, it is too high. It should also be smooth, and formed from sheet metal into a U-shape.
    The steering column is too high, it should be lower with a sheet metal trim piece. The steering wheel is wrong, it should have triangular holes in it.
    The entire electrical board is all wrong, it has the wrong fuse boxes, wrong voltage regulator in the wrong location, wrong 4-pole junction block.
    These things are just the tip of the iceberg that I can see from one photo. I'm sure that there are pages of other incorrect items that indicate that this is a replica.
    The question I have is this: If you were going to the trouble and expense of making a 250 TR replica, wouldn't you photograph and measure a real one and copy everything exactly? It's not rocket science, it's a very simple car and easy to copy. There is no reason that you couldn't make a replica that was so realistic that it would fool an expert.
  20. Motob
    Motob Formula 3
    Nov 11, 2003
    2,143
    Berkeley, CA
    Brian Brown
    #20 Motob, Oct 26, 2008
  21. Jon Hansen
    Jon Hansen Formula Junior
    482
    Grand Rapids, MI
    Jon Hansen
    #21 Jon Hansen, Oct 26, 2008
    The original's steering wheel looks very similar to an old wheel I picked up years ago. The wheel I have is marked "WALSALL WHEELS LTD. ENGLAND", and it is 17 inches in dia. It does not have the 2 tone wood however. Does anyone know what size and brand steering wheel was used on the old TR's?
  22. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    2,788
    FRANCE
  23. 3406-kris
    3406-kris Rookie
    Sep 7, 2006
    46
    Las Vegas
    Kris Kincaid
    The crazy thing about these replicas is they aren't cheap. With hundreds of thousands of dollars on the line, you'd think constructors would pay more attention to details. At least fly to a car show where an original is on display an take photos.
    Thanks for the photos Motob. You don't see a lot of good detail photos out there.
  24. ferrarip4
    ferrarip4 Formula 3
    May 8, 2008
    1,208
    Sydney, Australia
    Chanh Lê Huy
    #24 ferrarip4, Oct 27, 2008
  25. Ed Niles
    Ed Niles Formula 3
    Honorary
    Sep 7, 2004
    2,433
    West Hills, CA
    Edwin K. Niles
    Nice to see 0716TR, but you should know that it had a Drogo berlinetta body when I had it, so what you are now seeing is not original.
    635CSI likes this.
