348 - Side mirrors | FerrariChat
348 Side mirrors
Discussion in '348/355' started by JLF, May 9, 2023.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    My side mirrors do not work. I have the plug out. Is there a way I can test the plug to see if it’s getting power so I can see if it’s the wires or the switch?
  2. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    Normally the problems with the 348 door wiring is under the boot where the the wiring loom attaches to the door frame . There are around 23 wires going from the door to the bulkhead. (as in every other car) The unfortunate problem with the 348 was the factory left insufficient "strain relief" in the door harness such that when the door is fully extended in the "Open" position the door is pulling at the connections to the pins in the 1/4 turn black plastic plug. Which will eventually fail.
    albert328gts likes this.
  3. Qavion
    Qavion F1 World Champ
    14,268
    Ian Riddell
    Both mirrors?
  4. Qavion
    14,268
    Ian Riddell
    The control wires going from the switch to the driver's mirror don't go through door hinge connector, but the power wire for the switch does.
    Look for 12 volts on pin 4 of the mirror control switch connector. Pin 4 should have a blue/black wire on it. Use any bare metal as an earth for your voltmeter's black probe.
    Check this with the ignition on.
    It won't be a fuse issue. Your wipers, brake lights and glove box light wouldn't work if the fuse had blown.
    If no power on the blue/black wire, go the driver's door hinge connector and inspect/check the blue/black wire there (pin 11).
  5. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Thanks a lot. I pulled the plug off at the door and everything “looked” ok. I will check that pin today.
    Yes, both mirrors.
    Qavion likes this.
  6. Qavion
    14,268
    Ian Riddell
    Here's a close-up of the door plug. I think this is the contact side of the A pillar connector.
    Keyway at the top.
    Check for voltage across pins 11 (fuse 5 power) and 13 (earth)
  7. Qavion
    14,268
    Ian Riddell
    Pin 3 (red wire) on the switch seems to supply both mirrors (with fuse 5 power). I suppose the red wire could be broken (but less likely, compared to the door plug wiring)
    Full mirror wiring diagram here:
    https://www.dropbox.com/t/FsU46ImpWOl515hN
  8. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Thanks Qavion. Very helpful.
