Silencer | FerrariChat
Silencer
Discussion in 'Technical Q&A' started by Philjay50, Jun 17, 2007.
  1. Philjay50
    Philjay50 Formula Junior
    Jan 16, 2003
    595
    Chester, England
    Philip
    #1 Philjay50, Jun 17, 2007
    For those of you that have often wondered what is inside a 308 or Mondial Silencer (muffler to our colonial cousins) here's one I oped up earlier.
    It rattled like a tin can with stones in it so I cut it open to see whats inside. I have often wondered. To state the obvious, the pipes come lose. Not much in there for your money.
  2. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    927
    Europa
    Bob
    wow, you made a really neat job of cutting that open. If had been me it would have looked as if I'd hacked it with a machete.
  3. f355spider
    f355spider F1 World Champ
    18,044
    What is the plan? It does not look to be in that bad a shape...tack weld the pipes in place, then weld the sheet you cut out, back in place?
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    This was my plan for the 355 until I found out I have a Tubi already...While you're in there I'd remove some of that baffling then seal her up :) DIY Tubi!
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    As far as flow, that muffler looks like crap inside.
    It would make me ill knowing my exhaust had to go through that mess.
    Time to upgrade.
    Good luck and have fun!!
  6. Philjay50
    Jan 16, 2003
    595
    Chester, England
    Philip
    I have done a bit of surgery with some advice from a pal that works for an exhaust manufacturer. Welded all the pipes up and had the hole covered.
    Just need to get around to fitting it.
