Silentbloc replacement | FerrariChat
Discussion in '308/328' started by david bentley, Feb 13, 2016.
  1. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    #1 david bentley, Feb 13, 2016
    Changed the Silentbloc at the transmission end of the shift linkage.
    It was a heavy press fit in the part extending out of the engine/trans
    Made the shown tool to push the old bloc out and the new one in
    Job takes about 30 minutes!
    Put the transmission in third gear and worked in the space between the engine and frame crossmember
  2. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    nicely done. possible to provide all measurements?
  3. Rifledriver
    37,288
    I just use a pair of sockets.
    Never owned a tool for the job.
  4. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Thought about two sockets and a C clamp but could not see how to get in there!
  5. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    I guess if you can do it with two sockets...I waisted my (and your) time!
    To answer your question, the only "critical"dimensions are those for tube C
    You key off the dimensions of the Silentbloc
    My replacement had an OD of .630 so I made C with an OD of .585
    The OD of the center tube of the Silentbloc was .390 so I made the hole in C .395
    Hope this helps you
