Silicon Brake fluid for 365BB ok?? | FerrariChat
Discussion in 'Boxers/TR/M' started by Patrick365, Nov 6, 2012.
  1. Patrick365
    Patrick365 Rookie
    Jun 17, 2009
    41
    Manila, PHILIPPINES
    Patrick Elam Torres
    Hi All!
    Just wondering if anyone has tried Silicon brake fluid on their 365bb? I am aware that some rubber parts from cars brake systems originally designed for dot 3 or dot 4 respond negatively, but some do ok.
    So may i ask the 365bb owners who have tried silicon brake fluid what their experiences were as far as braking performance goes? Did you just (hopefully) clean out all of the dot 3 or 4 fluid, or did you change all the rubber seals on the entire brake system? Thank You!
    patrick
  2. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    Most car owners don't like Silicone, increases pedal travel. Just change the fluid every 2 years and be careful of the paint.
    Ago
  3. Patrick365
    Patrick365 Rookie
    Jun 17, 2009
    41
    Manila, PHILIPPINES
    Patrick Elam Torres
    AGO- I`m aware of the general tendency for the pedal to sink lower, but thanks anyway!
    I was hoping for a more specific answer since its my understanding that certain types of rubber designed for dot3 and 4 react in varying degrees to silicon fluid. Anybody else?
    patrick
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,540
    romano schwabel
    silicone brake fluid is very good for nearly never changing this fluid because this fluid is not hygroscopic ( no water will be mixed after a while like DOT 3 or 4 )
    but when you move to this silicone fluid you have to change ALL rubber parts. so the sealing rings in the mastercylinder, in the calipers and also replace all brake hoses.
    but I prefer changing the fluid every 2 years, much cheaper.
    to put in silicone brake fluid may be a good option after a totally restauration
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Never use silicone brake fluid in a Ferrari.
    NEVER
  6. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,043
    I have had silicone fluid in my 365 Boxer since 1987 with zero problems. Did not disassemble anything, just changed fluid. I change the silicone every ten years, but just because I feel guilty. Brake pedal being lower is just a "story". Silicone requires careful bleeding, mostly by gravity, then the pedal will be as good as any other type of fluid. I have it in all my Ferraris and non-ABS cars with no issues. Started using it in 1977.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Let me be more clear, NEVER use silicone brake fluid.
  8. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,043
  9. turbo-joe
    Apr 6, 2008
    9,540
    romano schwabel
    this is really one of the best articles I have read in english.
    thanks for posting the link.
  10. Dr Tommy Cosgrove
    36,437
    Birmingham, AL
    Tommy
    LOL
    You sound like me and 134 in the a/c!
  11. dave80gtsi
    dave80gtsi Formula 3
    1,920
    Ohio
    Dave Meredith
  12. Patrick365
    Patrick365 Rookie
    Jun 17, 2009
    41
    Manila, PHILIPPINES
    Patrick Elam Torres
    Guys, thank you for all the replies!
    DWR46- May i ask exactly what brand silicon fluid you used for your boxer? All silicon fluid is dot 5 right? And thanks for the article!
    DAVE80GTSI- Thanks for the link as well!
  13. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,043
    Patrick: To the best of my knowledge, Dow Chemical makes all the silicone fluid. I would buy any name brand fluid. Over the years, I have used Dow, private brands and lately Car Quest brand.
