Silicone Coolant hose install | FerrariChat
Discussion in '348/355' started by Sonnythebull, Nov 10, 2024.
  1. Sonnythebull
    Sonnythebull Karting
    Nov 6, 2024
    78
    Sonny Dabull
    hi everyone can you swap out all the coolant hoses with silicone ones without dropping the engine?
  2. carnutdallas
    carnutdallas Formula 3
    1,970
    Dallas Burbs
    Rob
    No, don’t thinks so….. Also, my Ferrari dealer and the team that does all of my cars, can confirm they are a waste and while nice to service with as they don’t “adhere” to the metal as much, in their experience they leak! And I am dealing with that on a car I bought.
    marioz likes this.
  3. Sonnythebull
    Nov 6, 2024
    78
    Sonny Dabull
    Really? Because I have them on other cars and on all my motorcycles that i ride on the track and I’ve never had a leak. They are supposed to be much less prone to leaking than rubber
  4. carnutdallas
    1,970
    Dallas Burbs
    Rob
    The original hoses, are formed better and we have found the silicone hoses don’t have the exact original pattern. Of course silicone as a material has advantages and we could agree that in theory and practicality it should be an improvement. But of the cars I own, and others serviced by the team that I support and use, we have not found the best experience adapting what is available for our cars, to be superior or without issue. I am just reporting based on your inquiry and I felt you should have that info. It will probably be fine, but we have chosen to not continue their use. :)
    marioz likes this.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    I have not found silicone hoses to be an improvement.
  6. Sonnythebull
    Nov 6, 2024
    78
    Sonny Dabull
    Thanks for the info! I’ll look into this more
  7. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Agree. Due to leakage, I just had to remove a whole assortment of these "upgraded" hoses installed by a prior owner that were branded from a vendor that sells or used to sell "upgrade/performance" kits within in this community. Swapped all back over to OEM and no longer have leakage issues. So much for the upgrade, back to happy leak free motoring. In general these types of hoses seem to need an uncomfortable amount of clamping to not leak and even then not a sure thing.
    Rifledriver, carnutdallas and marioz like this.
  8. Sonnythebull
    Nov 6, 2024
    78
    Sonny Dabull
    thank you. Where did you find the OEM hoses? And can they be installed without dropping the engine ?
  9. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    287
    If your hoses aren't falling apart, then I'd wait until the next engine out. Much easier to access the rad hoses than trying to replace them with the engine in.
    the ones to the expansion tank are easily accessible, so you could do them immediately.
    the little S bend one from the H2O pump maybe doable from above, but its a tight squeeze (although you could drop the tank I guess to access everything easily).
    As to material, I've gone silicone and have no leaks I'm aware of. Whatever you choose, it'll be an upgrade to 30yo rubber...
  10. yelcab
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    You know what else is an upgrade to 30-year old rubber? New rubber. Every 5 years with an engine out, I make it a habit to always cut the 7 water hoses at the front of the 355 engine near the fire wall and replace them with run-of-the-mill rubber hoses I get from Oreilly's. I take the 90 degree right angle hoses, and the small S hose to the store and match up a run-of-the-mill hoses that have a section I can cut off to match those hoses. They don't cost $1,000 and in five years, I'll replace them again.
    By the way @Sonnythebull, you can replace all seven hoses at the front with the engine in the car. Take the lid off, sit in the engine bay, you'll have plenty of access.
    Sonnythebull and Rifledriver like this.
  11. cactussed
    Mar 12, 2008
    287
    Oh, whilst you're at it, replace the jubilee clamps with new ones also...
    Sonnythebull likes this.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    I own a hose company
    The OEM are the best design for the 355. They are top of the line purpose made hoses.
  13. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    Hose don’t wanna be saved.
    Sonnythebull and INTMD8 like this.
  14. yelcab
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Tim, you are getting hosed !
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    I'm the big hoser LOL
  16. willrace
    willrace Three Time F1 World Champ
    34,919
    North Tay-has
    Kurt
    So, yer saying "Take off, hoser, eh!"?
  17. ShineKen
    19,892
    Southern California
    Nostradamus
    Tim’s got lots of hose.
