Silver gauge trim | Page 2 | FerrariChat
Silver gauge trim
Discussion in '348/355' started by drbob101, Sep 14, 2014.
  1. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Bob,
    I understand about the center vent. My questions now are about the 2 side vents near the doors. Dave suggested there are tabs on all 4 sides of each vent. His pic of the driver's side vent seems to show one near the bottom right side corner. It would help to know where they all are. Any pics of these?
    Jerry
  2. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Jerry,
    I'll pull one out later and take pictures of all sides.
  3. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    My right vent was not sitting properly in the opening so here it is.
    Lets use the terms window side and radio side so as to not confuse left and right when speaking of the left and right vents in the car.
    Note the broken tab on the top window location on mine.
    The location of the four vents are as follows:
    Top of the vent window side corner
    Top of the vent, radio side corner
    Lower side of the vent, radio side
    Bottom of the vent, window side corner
    The two tabs on the window side, top and bottom are appendages that will be prone to breakage on removal. The other two are more molded into the body of the vent and sturdier.
    I think releasing those window side tabs first would be best then work your way around the vent and take what it gives you. I am going to try and epoxy that broken tab but am not optimistic it will hold.
  4. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Thanks Bob. Pics tell a thousand words. Hearing you and Dave talk about this, you guys both make it seem like these come right out....no big deal. After I try it, I'll see if I agree. :)
    Hope you get the repaired tab to hold. But I agree, epoxy on plastic, especially where you're going to put some stress on it, may not hold. Much better would be a solvent type "glue" made for "welding" plastic. It has to be the right type for the plastic you're working with and I don't know what type the vents are made from but it actually "melts" the plastic surface and literally "welds" the break back together. AFAIK, its as strong as the plastic itself. Good luck.
