Simple 2.7 slow down ECU replacement - only for no cats | FerrariChat
Discussion in '348/355' started by wbt, Nov 26, 2016.
  1. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    #1 wbt, Nov 26, 2016
    So I have been chasing slow down lights for a while on my 2.7 355 which is frustrating due to the fact I have had the cats removed. I do not wish to spring for 2 new CCU's and possibly new thermocouples to fix a problem that doesn't actually exist. I have designed a simple circuit that replaces the cat control unit and sends a constant signal to the motronic unit. Results so far is I have had no pesky slow down lights and bank shutdowns.
    I should note - DO NOT USE THIS SETUP if you still have cats. The thermocouples are there for a reason!
    The vescovini CCU simply creates a linear 0.5 to 5 volt signal for the main motronic ECU depending on cat temperature. Normal range seems to be between about 0.5 and 3.5v, over 3.5v the light flashes, and nearer 4v it stays on solid and shuts down 1 bank of cylinders. So, a 2.5v signal should do nicely to fool the ECU. There are various threads around that detail the CCU operation in more detail so I'm not going to get into that too much here. Suffice to say 2.5v has been tested on my car and works perfectly.
    The circuit is simple - a 2.5v zener diode in series with a 1200 ohm resistor to limit current to a theoretical less than 10mA to protect the circuitry (both motronic and the zener). The motronic has a weak internal pull up to 5v on the signal wire, so this circuit requires no power supply or connection to the 12v wire (pin 1). Pin 4 is unused on motronic 2.7 as far as I can trace with a scope during normal operation. So this circuit only requires 2 wires to connect to the motronic ECU. The 4 way connector is easily sourced on ebay (I got a 5 pack for a few dollars from a seller in China) with a standard crimping tool this creates a perfect waterproof fit to the existing CCU wiring loom.
    All up 2 CCU replacement modules can be created for just a few dollars and the slow down light issue is permanently fixed. Win.
    I haven't tested this circuit on a 5.2 car, but in theory it should work the same. If motronic has a weak pull up to 5v on the signal line then it will work.
  2. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    #2 wbt, Nov 26, 2016
  3. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    #3 wbt, Nov 26, 2016
    2 units fitted to the car. I have just cable tied them to the engine side main loom so they don't even need to be disconnected when doing the major service. The weight and size is minimal so I do not expect vibration to be an issue.
    Engine running, no slow down lights!
    Many dollars saved which can go nicely towards the Christmas beer fund :)
    ernie and F456M like this.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  5. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The type of first hand technical knowledge this site so needs.
    Great work.
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    5.2 motronics carry a 5v bias voltage on the signal line as well so this should work identically.
    Nice work!
    I know someone with a 5.2 who deleted the cats and has a persistent sdl associated with the bypass valve TC. He has been waiting on Goths bypass box to try just this at that location.
  7. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Very nicely done. And you gotta love a guy who has a Christmas beer fund. :D
  8. baschul
    baschul Karting
    May 27, 2015
    177
    Dallas, TX
    Brian S
    Great work!
  9. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Outstanding!
    Thanks for sharing.
  10. Qavion
    Qavion F1 World Champ
    13,959
    Ian Riddell
    Wot??? No Cavallino Rampante on the plumbing end cap??? )))
  11. fatbillybob
    Aug 10, 2002
    28,678
    socal
    This is great! This takes what I started years ago with a 1.5V battery to the next level. I never liked the idea of Ferrari trying to idiot proof the car with the SDECU dialing back the motronic when temps got hot. I would rather have and indicator since I still have a brain. I think you can use your method with cats IF there is another way to monitor and alert the driver. For Example, I used EGT when I went manual on the SDECU's. I get more information about car running from EGT too. So EGT with an Oil style idiot light would be fine IMO. Otherwise I have high hopes for Goths SDECU's sold through Ricambi. Good job!
    For those electrically challenged can you go through what made you look and how you figured out the 5v pull and what does a zener do? Always want to learn more...
  12. Skippr1999
    Skippr1999 F1 Rookie
    4,489
    That's me !
    Should this keep the CE light off for the code 1448 Bypass issue ? Goth did not send his bypass version TCU to ricambi unfortunately. Not sure what's up with that.
    Still hoping for the answer. Car loves being "unleashed"!
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Skipp - I would try this for your bypass location.
  14. Skippr1999
    4,489
    Thanks. I'll see if I can get one made and report back.
    On a brighter note, I own property in a state that doesn't require inspections. Guess where the car is headed to........
  15. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,663
    It might be fun to take the present circuit to fool the SDECU and then attach the thermocouples to a meter so we could just see the temps on a dial in the cabin.
  16. fatbillybob
    Aug 10, 2002
    28,678
    socal
    That's what I did. I think it is in my original thread. All the parts were from aircraft spruce
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    WBT. Check your PM box please.
  18. Ricambi America
    Sponsor Owner
    They are now completed by Gothspeed and scheduled for shipment to Ricambi. We'll get there, neighbor!
  19. Skippr1999
    4,489
    Thanks Daniel. Please let me know when they arrive.
    Skipp
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,843
    Richmond
    Pete
  21. Skippr1999
    4,489
    All the discussion seems to be about SDL. Will the same strategies solve CE lights ?
  22. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    SKipp, the bypass location SDECU activates a CEL (your issue) and not a SDL (cat locations).
    IN your case its about sending the Motronics a 'happy" voltage that doesn't trigger the CEL. As we don't know what voltage your BP SDECU is sending out right now, I am unsure what is creating the CEL and why.
    In Jevs thread above he used .5V at the BP location and all was fine. That would be where I would start. I can assume that Goth's piece outputs something similar.
  23. Skippr1999
    4,489
    I'll buy Goths and report back. Thanks to everyone who has helped me.
  24. Qavion
    13,959
    Ian Riddell
    Gents, has anyone tried this on a 5.2 yet? I made a few of these simple plugs and am thinking about fitting them (haven't built up the nerve yet) :D
    I even managed to fit the diode and resistor into the plug (no external wiring).
    Cheers
    Ian
