Simple Electrical Question | FerrariChat
Discussion in 'Technical Q&A' started by Dr Tommy Cosgrove, Oct 16, 2008.
  1. Dr Tommy Cosgrove
    36,579
    Birmingham, AL
    Tommy
    I am not much of an alarm guy but I do see the benefit of a nice little blinking red LED deterrent light. Years ago I had one in my 308 but A friend rigged it up for me and I cannot remember how in the world he did it.
    So, How would I rig up a blinking LED that comes on AFTER I turn of the ignition? This is not something I can't do myself after a trip to RadioShack. I just need the details on what to hook up and to where for the ignition off/light on thing
  2. PAP 348
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    #2 PAP 348, Oct 16, 2008
    Hi Doc,
    Easy one mate, go and get your blinking LED from Radioshack a inline fuse holder and also a Bosch relay with 87a and 87 pins and connect it as follows.
    Bosch Relay
    Pin 85 > You ignition source 12V+
    Pin 86 > Ground for you ignition Source
    Pin 30 > Fused 12V+ source to supply the LED
    Pin 87a > 12V+ source to your LED
    Pin 87 > NOT USED
    Hope this helps :)
  3. f355spider
    f355spider F1 World Champ
    18,054
    #3 f355spider, Oct 16, 2008
    What he said! :)
    I did exactly the same on a Honda I had a few years ago, and it worked great. No alarm hassles, and I never had the car tampered with or broken into. Took all of 20 minutes to wire up cleanly. The blinking LED came from Radio Shack (includes a small black sleeve) and I had to source the relay from a better stocked electronics shop. (I asked for a "normally on" relay, that when energized, cuts power to the device, which is the opposite of what most applications do) I then tapped a wire off the ignition switch that was hot when the ignition is on. I drilled a hole in a spare blank plate in the dash, that was used for a fog light switch (which my car did not have) and slipped the light and sleeve through from the front.
    I never bothered in my 308 or 328, since I believe most thieves would assume a Ferrari has an alarm, whether they see the blinky light or not.
    The trick on a 308/328 is where to mount the light(s?). Near the door lock pulls? That would be ideal...but who wants to drill that? Somewhere on the console? Same deal, what to drill?
  4. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    More expensive but much easier. Buy a Hill Engineering shift gate lock for $100. The car is going now where fast with that installed.
  5. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Doesn't deter a brick through the window from those intent on stealing less than the whole car. The LED does seem to.
  6. Dr Tommy Cosgrove
    36,579
    Birmingham, AL
    Tommy
    Thanks guys.
    You don't need to drill a hole. The Radio Shack blinky is so small I just wedged it between the bottom of the steering column and the little screwed on leather thing below it. I just had it poking out just enough to see it. No holes needed.
    I have the shift lock too but the blinking light is just so cheap and so easy that it falls under the "no brainer" heading here. I mean if it just makes ONE person pass it by... Know what I mean? There is just no downside at all to having one, really.
    I appreciate the help. I'll post pictures this weekend.
  7. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    If that is the goal, neither will the light. An alarm won't deter a snatch and grab. Not like there is much of a place to lock anything up in these cars anyway.
  8. DGS
    DGS Seven Time F1 World Champ
    72,872
    MidTN
    DGS
    Even easier to wire up would be to just have a switch to turn it on or off.
    LEDs don't draw a huge amount of power, but there might be times (say, over winter) where you don't want it drawing from the battery.
    You don't need it in your own garage, for example.
    Of course, a hand grenade hanging from the mirror can also be a deterrent. :p
    A funny thing about alarms: Every time I drive the 328 through the underground parking garage, the exhaust note sets off one or two car alarms. And almost always on cars that I can't imagine anyone wanting to steal.
    What's weird is that the EVO sometimes sets off an alarm -- and the exhaust isn't any louder than the stereo. ;)
  9. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    You're right about the room for anything.
    I guess the other depends on how fleet of foot our potential thief is. In an increasingly over-weight world I'd rate deterring a fat slob of a vandal as a useful result anyway.
  10. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    LOL! OK, got me on that one. But the grenade is a good one as is the mounting of the 30 Cal. from another thread! (Helps with old slow drivers down here in the Land of the Dead.)
  11. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    PAP!! How come you didn't tell us before that you are also an Electrical Genius??!!! :D
  12. PAP 348
    Dec 10, 2005
    100,228
    Pap
    :eek::eek:
  13. f355spider
    18,054
  14. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    locks are for honest people. the bigger the lock, the more people you keep honest.
  15. Dr Tommy Cosgrove
    36,579
    Birmingham, AL
    Tommy
    Actually I NEVER lock my 308. In fact the passenger side actuator has never worked in the 11 years that I have owned it.
    If they want something inside the car. I don't want them breaking something to get it.
  16. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,663
    Engine Bay, Georgia
    George C.
    Hi Doc,
    A thought for your consideration. Along with your blinking light, why not install a kill switch to either the fuel pump [if it is electric], or some other electrical ignition component that would render the car undrivable when the switch is engaged?
    Ciao,
    George
  17. mwr4440
    58,038
    Bavaria, The 'Other' Germany
    Mark W.R.
    In my '81 308 the red blinking light was mounted between the OIL Temp gauge and the Clock. Convienient and vizable.
    AND if you ever want to remove it in the future, just recover with new leather the little tin surrround in the center counsole that the gauges are mounted in and no one will ever know you drilled it.
  18. PAP 348
    Dec 10, 2005
    100,228
    Pap
    How did it go Doc? did you end up doing it?
  19. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    +1. I don't even roll the windows up. I just won't park it anywhere for too long or where I can't see it. If I go into a store, I put a gate lock on the shifter and a steering lock on the wheel, and leave both windows rolled down.
    I don't leave anything in the car that anyone would want to steal. Anything they would steal inside the car would be preferable to having to source window glass!
    Birdman
  20. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Easy install......http://www.amazon.com/Moroso-74103-Battery-Terminal-Disconnect/dp/B000COO1P4/ref=pd_sbs_auto_1/186-6059670-6052568
    I prefer this type of switch for its convenience + great for when car is parked for a period of time to prevent battery drain (which we all know Ferraris have). It should be connected to the ground cable side of battery & can be mounted in an inconspicuous location.....
    http://www.amazon.com/Cal-Term-41860-Switch-Battery/dp/B0007MCTQ4/ref=pd_sbs_auto_5/186-6059670-6052568
  21. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Wouldn't just pulling the left side battery quick disconnect do the same thing?
  22. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Yes it would, & in the privacy of your garage, that's fine. A keyed switch discreetly hidden & conveniently available in the cabin avoids the in & out of the battery area every time you park the car (not to mention the 'advertising' by fooling w/battery in public).
