Simple exhaust bypass valve question | FerrariChat
Discussion in '348/355' started by Orange Crush, Oct 22, 2015.
  1. Orange Crush
    Orange Crush Karting
    Dec 30, 2009
    101
    Wichita KS
    Rob
    I checked the search and couldnt really find an answer so I'll give it a try.
    Does the Bypass open under throttle pressure or over 4K rpm at any given time? Mine is always activated by throttle pressure(75% or so) in any gear but from my understanding I thought it still is supposed to open over 4K RPM with less throttle input? I have a '95 MY with Capristo Stage 2 or 3(cant tell) and hi Flow cats.
    Appreciate the help and sorry if this was discussed and I missed it!
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,797
    Lake Villa IL
    There is an RPM threshold in each gear and later for 2nd gear I believe.
    I think there must be a TPS threshold as well because if I bring up the rpm's with low throttle input the valve doesn't open.
    So, not sure what the threshold is but I believe there is one for rpm and tps that must be met. (or seems so on my car)
  3. WATSON
    23,832
    WI
    Bypass valve opens:
    80% throttle +
    Various RPM thresholds based on what gear you are in.
    I had the RPM / gear detail and posted it here a while back. I'll try and find it later.
