360 - Simple Newb question | FerrariChat
360 Simple Newb question
Discussion in '360/430' started by 88Mondialguy, Mar 24, 2020.
  1. 88Mondialguy
    88Mondialguy Rookie
    Oct 22, 2017
    33
    Chris Toperczer
    So I opened the Engine Compartment Hood and tried to close it by holding it approx 20 cm from open and letting it drop. Still feels like there is a little give - don’t think it’s fully closed and don’t want to slam it shut because of the huge window!
  2. aleary360
    aleary360 Karting
    Nov 23, 2015
    172
    Westlake Village, CA
    Al Leary
    Push down. Don't slam it
    Flea7 and EastMemphis like this.
  3. 88Mondialguy
    88Mondialguy Rookie
    Oct 22, 2017
    33
    Chris Toperczer
    Of course did that - still feels like there is some play
  4. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,948
    Melbourne Florida
    KGC
    Ive noticed on my coupe that while the deck lid is adjusted and latched properly that there is some "flex movement" along the length of the lid. Been that way and it doesn't appear to be anything to prevent it.
  5. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    628
    Eden Prairie, MN
    Matt
    Try starting the car, if the deck lid is open I think either won't start or won't go into gear (assuming you have a F1).
  6. PGI
    PGI Karting
    Oct 24, 2017
    52
    Ken
    Speaking of lids, remember to push down on the emblem when closing the front lid.
  7. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    My 360 was the same. When latched there was play, you could the lid vibrating up and down in the rear view mirror while driving. There are shim plates under the latch (on the lid from memory) I took one out and it tightened up nicely.
    Oh and I would not push down. The drop method is more recommended. But yes push down on the emblem for the front.
  8. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    You may have to adjust the cable. Mine was coming completely unlatched while driving. Simple adjustment to shorten or lengthen the cable. If you do make an adjustment, recommend testing the emergency hood release before closing the hood.
