simple question: glue | FerrariChat
Discussion in 'Technical Q&A' started by spike308, Feb 4, 2004.
  1. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,481
    Austin TX!
    Mike Z
    simple question:
    what adhesive would you use to re-attach rubber weather stripping on the door that is coming off?
    thanks!
  2. Bob308GTS
    Bob308GTS Formula 3
    Sep 26, 2001
    1,148
    Aurora,IL
    Bob Campen
    3M weather strip glue, tube or spray suggest the tube in black
  3. rossofiorano355
    rossofiorano355 Karting
    Dec 22, 2003
    210
    NOLA - Bham
    Ron
    Concur - 3M Weatherstrip Adhisive in the tube
  4. Quasimotor
    Quasimotor Formula Junior
    Jan 4, 2004
    325
    Yonkers, NY
    George Avgerakis
    The above two answers might be correct, but you should know that 3M has a vast array of adhesives and that each has a specific range of attributes and limitations. For instance, I called 3M to find out what type of glue to use to adhere the foam strips to the bottom of my forward hood panel (308). At first the 3M engineer told me one type, then backtracked to tell me "Oh no, that won't work, it has too low a temperature tolerance" would fall off after glue got 100 degrees F!
    I would suggest going to 3M website and getting the 800 number to find out the best 3M product.
    I cut to the chase and use simple contact cement. It works fine all over my 308.
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    As far as I can tell, 3M super weatherstripping cement is contact cement. ie; If it smells like & quacks like...
    It works very well. Also in a pinch I've used GOOP which also works well. Both hold up for years...
  6. nickm
    nickm Formula Junior
    Jan 20, 2004
    371
    Ventura Ca.
    Dont get the glue on your hands though. You'll have to wear it off. :)
  7. nickm
    Jan 20, 2004
    371
    Ventura Ca.
    The black 3M that is!
  8. yank05
    yank05 Formula Junior
    Nov 8, 2003
    272
    New England
    Anthony
    What is the best product to clean off old glue without harming the paint underneath?
    Thanks,
    Anthony
  9. 308 GTB
    308 GTB F1 World Champ
    11,189
    New Jersey
    Barry Wolinsky
    Anthony,
    I've used "Res-Off" to safely remove residual old, dried balance weight adhesive from my wheels. It's something I just happened to have here in the office which I use to remove adhesive residue from skin after dressings are removed. It contains no naphtha or acetone. It worked beautifully without affecting the painted wheels. It would probably be safe for the paint on the car as well. You can get it at a surgical supply center.
    Barry
  10. yank05
    Nov 8, 2003
    272
    New England
    Anthony
    Thanks Barry, great tip!
  11. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,792
    Palm Beach, FL
    Rob
    WD-40 also works surprising well and is something you probably have in the house already
  12. dm_n_stuff
  13. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,648
    Land of Slugs & Moss
    Han Solo
    I use Permatex brand BLACK weather adhesive #82 I think. Comes in an orange box. Napa Auto Parts can look it up for you. Basically it's black contact cement.
    For clean up I suggest heavily waxing the areas around where you are going to glue. Using 'Goofoff" or even lighter fluid might work. The lighter fluid trick was told to me by a body man. Works good on road tar too, without messing up the paint.
    DJ
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Mineral Spirits (which is more or less what lighter fluid is)
    Waterless Hand cleaner (WITHOUT PUMICE)
    Citrus based degreasers & parts cleaners.
    Goo-Gone
    Goof-Off
    Road Tar Remover
    Final Wash pre-sanding cleaner
    WD40
    LPS
    Naptha
    Coleman Fuel
    Enamel Reducer (NOT lacquer thinner)
    Kerosene
    All contain solvents that are pretty good at taking rubberised adhesives such as trim cement & contact cement off. Most will also strip wax, but it does resist them somewhat. Most won't attack common automotive paints if used sparingly not left on for more than a couple of minuites.
    Plan on washing the surface afterwards as there's usually an oily residue left behind.
  15. yank05
    Nov 8, 2003
    272
    New England
    Anthony
    I am going to try my Goo Gone tonight - have to clean up and reattach the carpet pads under the bonnet.
    Thanks!
    Anthony
