single distributor cap 308 / differences between breaker and electronic version ? | FerrariChat
Discussion in 'Technical Q&A' started by Martin308GTB, May 18, 2005.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Hello all,
    I wonder whether or where's the difference between the distributor caps for electronic ignition or breaker contacts version.
    At least Ferrari lists two different parts numbers for them.
    Does anyone know any details ?
    Occasionally some come up on ebay, but no seller can state whether it's electronic or contacts.
    Best Regards from Germany
    Martin
  2. shenbec
    shenbec Rookie
    Nov 21, 2003
    14
    The electronic ignition cap has two small rectangular holes at the base of the cap for the electronic sensor wires to leave the distributor. The single breaker cap does not have these. I mistakenly bought the wrong one and had to do some slight modification with a small file, but otherwise has worked well for the last three years. That is the only difference that I know of.
    Chris
    80 euro gtb
  3. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    Thanks Chris,
    this makes sense.
    Best Regards
    Martin
    '80 308 GTB
  4. thecarreaper
    thecarreaper F1 World Champ
    18,054
    Savannah
    we need to find a good source for caps $175 + each sucks .
  5. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    I have heard prices up to $225 for a usa 308. I went to the Norwood single distributor conversion for the $26 dollar cap, single distributor simplicity, elimination of the points with a magnetic pickup and near stock, (euro) appearance. Parts should be available just about anywhere. cheap.
    hth,
    chris
  6. Martin308GTB
    Jan 22, 2003
    4,259
    Martin N.
    over here there are Alfa dealers - the single dist. breaker version cap is the same like on the Montreal - who charge EUR 355,--. These are around $ 440,-- with today's currency conversion rate.
    Best from Germany
    Martin
