Single Distributor Car - PM1-4 or +6, what should Plug #1 point at? | FerrariChat
Discussion in '308/328' started by Andy 308GTB, May 29, 2022.
  1. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    I have an ongoing minor crisis of confidence. Considering I've done this process in the past it's never something I've thought about or in fact remembered. I have googled furiously and I cannot get the definitive answer. I can make arguments for both options. I'm hoping that my current set up is wrong as that would explain my current woe!
    If the distributor 'point' is aligned with the red mark on the distributor casing (i.e. Cylinder #1)
    Where should the indicator on the flywheel be pointing?
    a) PM1-4
    b) +6
    Thanks very much
    Andy
  2. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    +6, adjust distributor to points opening at this position for rear bank. PM1-4 is TDC position.
  3. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Thanks for the reply, I thought my thread was going to die a lonely death!
  4. Steve Magnusson
    26,776
    What is your "current woe"? Having the flywheel at +6 (near the PM1-4 mark) or at the PM1-4 mark when the dist rotor end for cyl #1 is pointing at the red mark on the dist housing rim really isn't much functional difference as you would rotate the distributor housing anyway to get the timing light to illuminate the +6 mark at idle. The much bigger factors are:
    1. to be on the correct rotational occurrence of the +6 or PM1-4 mark (when both cyl #1 valves are closed -- i.e., #1 firing), and
    2. whatever inside the distributor that is firing the 1-4 bank also has to be in the firing position when the distributor rotor end for cyl #1 is pointing at the red mark.
    Do you have the points system or the electronic trigger system?
  5. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    California SF bay area
    Paul
    Yes. the PM 1-4 mark comes around twice for a single rotation of the cams so you have to make sure the hash mark on the intake cam as seen through the oil filler cap is also aligned to ensure you are at TDC otherwise you'll be 180 out.
  6. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Hi Steve,
    You may wish that you hadn't ask...
    I have the electronic trigger system.
    Towards the end of last year I found that the car would accelerate and drive fine for a while but then, like a switch being flicked, it would get 'stuck' at around 4,000rpm and pressing the throttle would make no difference.
    Then after anything between a few seconds and a few minutes, the switch would be flicked and the car would leap to 5,000 rpm or wherever the throttle was being pushed to - and the car would be fine.
    I have worked through this methodically.
    1. I cleaned and lubricated the throttle pedal and the entire mechanism through to the carb linkages - to make sure nothing was physically sticking.
    2. I tested the plug leads and found one was faulty - I replaced the entire set. But the problem persisted.
    3. I cleaned and relubricated the advance/retard mechanism being very careful to make sure the springs etc. all went back as they came out.
    4. I checked that the distributor contacts weren't burnt and were clean.
    5. When I reinstalled the advance/retard mechanism and the distributor, I positioned the flywheel to sit on the +6 mark and then attached the distributor such that it was pointing at #1 cylinder (i.e. with the engine not running)
    6. I tested the carbs for air leaks but found none (and the problem was at higher revs not lower revs - the air leak would be more evident at lower revs)
    7. I tested the VR Sensors - one was showing 1,000 ohms resistance (should be 700) - so these were replaced and adjusted to be the required clearance from the reluctor. I also replaced the coils at the same time but this was probably unnecessary.
    At this point the car was starting fine. I set the idle to 900 rpm and the timing light showed the car was sitting bang on the +6 mark. I assumed the problem was cured.
    But out on the road, again at first the car was fine but after a few miles the problem at 4000 rpm returned.
    My thinking at this point was that this problem was heat related. As the various parts heated up (i.e. after a few miles drivng) the failure occurred. The most heat sensitive parts are the ignition modules. So I got a new pair of Hella ignition modules and installed them. I double.triple checked all the wiring has gone back correctly (King Leads/Plug Leads/Coil power/earth etc.). I've put a timing light on all the leads and they are all getting a spark.
    However, the car fires up but is now idling roughly at 500 rpm and misfires if I push the throttle.
    I pulled all the plugs and they were oiled (probably from driving around with the problem at 4000 rpm). I cleaned the plugs but the problem persists.
    A new set of plugs seems the most obvious next step - there is nothing else to replace!
    I didn't actually check that I was on the compression stroke when I set TDC but the fact that the car was running smoothly before I replaced the ignition modules suggests that I got lucky?
    If the timing was 180 degrees out, would it even start?
  7. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    Good, the experts are in
  8. Steve Magnusson
    26,776
    You may be right about that ;)
    Have to admit that that seems inexplicable. I would've commented that even though you have cleaned and relubricated the advance mechanism, that isn't the same as testing the advance mechanism behavior on a distributor testing machine -- it could be sticking/moving to a large advance, but the "pressing the throttle would make no difference" is just uber-strange (if you mean it's wrongly at a high RPM and pressing the throttle doesn't change the RPM at all). However, if I'm misinterpreting that and when wrongly at the 4K RPM, pressing the throttle does increase the RPM, IMO you've still got to rule in, or out, if it's a mechanical throttle problem -- e.g., a popped strand in the acc. cable can give some weird "works OK sometimes/sticks sometimes" behavior. If you can somehow visually confirm/deny if the throttle mechanism is returning to the proper rest position at the carbs, or not, when the 4K RPM happens might be a good thing to know. I'm just skeptical that anything in the VR sensors/ignition modules/coils parts of the system could do anything to greatly increase engine RPM.
    That sounds more like a bank not working, or you have some new problem. Do you still have spark on all 8 cylinders? Even though you can't change the relationship between when the #1 cyl fires and when the #5 cyl fires on your single distributor system, you can still measure it -- i.e., cyl #1 fires near PM1-4 mark and cylinder #5 fires near PM5-8 mark. Just grasping here, but your system allows for a lot of weirdness if things get mis-assembled/mis-connected so confirming each bank is roughly firing when it should be firing would be a sanity check.
  9. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    Thanks very much. Some very good ideas there.
    Just to clarify the 'sticking' at 4000 rpm problem, as this may help.
    If I was to gradually accelerate and continue pushing the throttle until the engine should be hitting 5000 rpm.
    - at 4000 rpm the engine note would change (into more of a thrum/drone sort of noise) BUT the revs would not increase, despite me pressing the pedal further.
    - at some point (seconds/minutes) the revs would suddenly leap to 5000 rpm (i.e. where I was expecting them to be on that amount of throttle) and the engine note would return to normal.
    My first instinct was that it was a mechanical problem. BUT this problem would only manifest itself after a few miles of driving. This has lead me to my latest theory - i.e. that it is temperate related.
    Also, and I've just realised this following writing it down above, the fact that the engine note would change at 4000 rpm but the revs did not increase, suggests to me that actual throttle mechanism aren't the problem - I think that the carbs are opening up and dumping more fuel in but it's not getting burnt or burnt at the right time.
    No need to reply to this with any haste. I am going to work through your suggestions and do a bit more thinking!
  10. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    Paul
    No I think it would just make some popping noises at best. To be honest I've never tried but this was a common thing on Alfa 4 cylinder engines because they used the same cam on both intake and exhaust so there were two marks 180 degrees out and sometimes when people put them together wrong rather than fix it they'd just swap the wires around, which would work but would leave a new owner scratching his head the first time he tried to do a tune-up.
  11. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    Can it be fuel delivery related? The pump might struggle once warm?
  12. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    I did test the pump when the car was cold and it was delivering plenty of fuel. The temperature theory hadn't entered my mind at that point. Testing that would be a challenge!
    Just to re-iterate that the problem at 4000 rpm happened out of the blue, the car has been running perfectly on the previous trip. I hadn't touched anything on the car for months.
    I was in the exact same situation following all the work detailed above - i.e. running perfectly for a while before the 4000 rpm problem kicked in.
    At this point, I replaced the Hella Ignition modules and now the car is idling at 500rpm and bringing it up to speed causes misfires (running lean?). I'm going to stick a new set of plugs in as the old ones had become fouled and go from there. By the time they turn up I will hopefully have cleared my mind!
  13. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    Paul
    I don't know anything about Hella ignition but what controls the timing advance? Low idle and not being able to rev sounds like it may be stuck in a retarded state.
  14. Andy 308GTB
    Jun 2, 2004
    2,666
    Essex, UK
    Andy M
    The advance retard mechanism works using centrifugal force - bob weights and springs. (Marelli SM805A). I have checked this and it was fine, I relubricated it whilst I was there.
    The Hella Ignition modules sit between the sensors on the Marelli SM805A and the coils - turning the pulses from the SM805A into triggers for the coils.
    I totally agree with your suggestion that it may be stuck in a retarded state. But at the moment I feel that I have exhausted that avenue.
    I'm keen to get the car back on the road but I am distracted with installing a new staircase at the moment!
