Single Lug TR Wheel Torque Setting | FerrariChat
Discussion in 'Boxers/TR/M' started by Roberto360, Jul 15, 2015.
  1. Roberto360
    Roberto360 Rookie
    May 25, 2013
    37
    Hello,
    Changing tires for the first time on a single lug '88 TR wheel.
    Question, what torque setting do I use to tigten the single lug?
    I can't seem to find it in the manual.
  2. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
  3. Roberto360
    Roberto360 Rookie
    May 25, 2013
    37
    #3 Roberto360, Jul 15, 2015
    Thanks,
    I must have done 5 different searches about this and came up empty.
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    This is what I do every time.....
    Clean the bevel on the wheel nut itself
    Clean the bevel on the axle shaft
    Clean the bevel on the wheel.
    Apply a LITTLE copper slip grease to all bevels
    Fit the wheel and tighten with the large spanner (use a thin cloth to protect the chrome) giving the spanner one good knock with the lead hammer.
    Drop the car and torque the bolt to 320ft/lb.
    HTH
    Phil
  5. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    In my opinion, cleanliness of the bevels and correct torque setting are the most important.
    The lead hammer and spanner is a good "get you home" when you have had trouble out on a ride...
    HTH
    P
