Size of distributor shaft o-ring? 1982 308 | FerrariChat
Discussion in '308/328' started by Speedsterbeast, May 27, 2024.
  1. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    Good day,
    I did a ton of work to my '82 308 in the past 4 months. I replaced the distibutor shaft o-rings and thay are leaking. I measured the old ones and ordered 19mm od X 15mm id X 2mm thickness.
    Does anyone in 308 land know what size they should be? The parts suppliers obviously do not list the size.
    Thanks!
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,575
    San Carlos, CA
    Mitchell Le
    They do leak a lot. Just keep trying until one does not leak.
  3. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    Or I could use the right size and do it once.
    Rifledriver and bitsobrits like this.
  4. Rifledriver
    37,106
    Are you talking about the cam extension that holds the rotor? On an 82 there is no distributor shaft so there is no distributor shaft O ring.
    Do you have a Ferrari part number?
  5. Steve Magnusson
    26,826
    +1 -- or an engine transplant, or a late carb 308 that came from somewhere else and got a "1982" year assigned in the documentation, or something else? Will be an interesting story no matter what ;).
  6. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    My 1982 308 DOES have an extension on the camshafts that the rotor screws on to. The O-ring goes between these two shafts. I cannot find the part number. Is my 308 ignition not original? I found the part number on the Quatrovalve parts breakdown. It's 109478. I did my valve shims this winter and it is definiately a 2 valve engine. It looks like we have a story here. I still need the size of those o-rings if anyone knows.
  7. Steve Magnusson
    26,826
    #7 Steve Magnusson, May 28, 2024
    Do you have a carbed 308 or a 308i-2V or a 308QV? Any of those could possibly be a "1982" in their documentation.
    The "coupling", item 33 here: https://www.ferrariparts.co.uk/diagram/ferrari/308-gtbi-gtsi/037-engine-ignition that goes into the cam on a 308i-2V does not show an o-ring. (And the part supercession makes no sense to me as the 117342 coupling 308QV part looks very different than 115587 coupling.)
    The "coupling" for a 308QV, item 33 here: https://www.ferrariparts.co.uk/diagram/ferrari/308-quattrovalvole/037-engine-ignition does have o-ring item 8 (Ferrari PN 109478).
    Can you post a photo of your engine family marking and/or your engine bay?
  8. Rifledriver
    37,106
    Steve, 81/82 does have an O ring. Its shown as part 49 but in the legend it is mismarked.
    To Cory, 109478 crosses to 15.6 mm ID and 1.78 section diameter. I have replaced them before. I coat it all with an anerobic sealant like Locktite 518 when I assemble them. Silicone there is a bad idea.
  9. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    Thanks so much! That explains why the 15 mm leaks. I guess I'll have to order the OEM ones and wait 1 more week before I get to drive the project.
  10. Rifledriver
    37,106
    Talk to Brian Keegan at T Rutlands. 800-638-1444
    WaltP and Dr Tommy Cosgrove like this.
  11. Steve Magnusson
    26,826
    No disagreement that they mangled that "49" o-ring stuff -- but that's in the US version 308i-2V SPC. The link that I posted is the euro version 308i-2V SPC that doesn't show an o-ring at all (might have one, and they just left it out completely from the figure and parts list, or could be that they initially didn't think that they needed one and added it later). I also see, that in both of those SPCs, there are completely different intake cams depending on whether the 115587 coupling or the 117342 coupling is used -- shows IMO that they must have been in a really tough spot as not being able to use the same camshaft is something that I'm sure they would've preferred to avoid.
  12. Speedsterbeast
    Nov 20, 2018
    31
    Thunder Bay Ontario
    Cory Zyromsky
    I ordered the part number 109478. It's listed for the QV, but I'm hoping it will work for the 2 valve.
  13. Rifledriver
    37,106
    For the period 80-82 Ferrari printed 2 parts manuals. MCP and Ricambi only show one. I have both.
    This is exactly why instead of looking it up and going it alone and crossing your fingers you employ the help of a real live Ferrari parts person who has been in this business as long as I have.
    Its why I went to the trouble of giving you a name and number.
    Or would you rather save a dollar and get more wrong parts?
