Skid Marks, How fast | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by pv908, Jun 17, 2006.
  1. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,782
    IgnoranteWest
    We have one of those here on the forum, I'll send him the link and see if he wants to respond.
  2. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    does he use PGR or Forza?
  3. FarmerDave
    Jul 26, 2004
    15,782
    IgnoranteWest
    tape measures and digital cameras.
  4. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    Front tyres locked, otherwise he would have spun.
    He clearly didn't know what the hell he was doing - to lock the tyres for that distance and still not figure out what was happening.
    No damn business driving a Miata, let alone any type of Ferrari, especially with no ABS.
  5. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    i'm thinking by that second pic at the 75m mark his anus would have had more foot pounds of torque than the testarossa.
  6. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    That's a very good first approximation, but by assuming m is the same on both sides of the equation you have implicitly assumed either 100% weight transfer to front tires and they are skidding, or that all 4 tires locked and are all skidding so can ignore weight transfer effects.
    Since only the front tires locked, a better approximation would have been to assign mass and CF values for fronts and rears. Assuming typical brake biase of 60% front 40% rear and ....
    Ahh... memories of freshman physics.
  7. scud
    scud F1 World Champ
    Oct 2, 2004
    11,803
    sad story but that comment ash , bwahaahaa
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,881
    The twilight zone
    m is the same on both sides by definition, there is only 1 car, it has one mass which is supplying the normal force for the friction and the momentum/kinetic energy, so it drops out. Your point about weight bias really isn’t valid in that the total mass still has to represented regardless of which axle it ends up acting on.
    What is valid is that the F front and rear are probably need slightly different math since the fronts where locked and the rears where not….that complicates it quite a bit. The front math is then as I wrote, just NCf. The rear is not locked due to brake bias differences, so Cf is not the limiting factor….but because the wheels were still turning, the Cf is closer to 1.0 than 0.8, so that probably cancels out the bias setting difference and then some.
    I don’t think there is enough data to get much closer, maybe alter the Cf value if there is some test data available, that is really the biggest guess…I mean assumption, I made, but I think it’s close.
  9. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    It should be easy enough for someone to do 130 kmh in their TR and stomp the brakes. At 85 mph I would bet that it takes MUCH less distance to slow to 45 kmh (about 30 mph) than 109 meters.
    BT
  10. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    No, m is not the same on both sides of the equation. True there is only one car with total mass m, but total weight (m x g) is not acting on one tire, which is what you have done in treating m as a point mass. It is distributed on 4 tires. So the weight transfer towards the front during braking will directly affect the frictional force generated by the front tires versus the unloaded rear tires. Cf will also be different on skidding front tires versus rolling rear tires.
    It is not my intention to argue with you nor nit pick your equation. As I said in my previous post, your estimate is a very good first approximation. For a slightly more accurate estimate, I suggested taking weight transfer into consideration, but even then we are still talking about using statics equations here.
    For accurate computer simulation, we will need to write the full dynamics equations, and take into account not only linear but rotational inertia, damping, etc.. Now that's complicated and will require a lot of testing to determine the simulation model parameters.
    Back in the late eighties I spent two years modelling the dynamics behviour of helicopters on rolling ship decks. We started with a statics simulation model, which we ultimately proved to be completely wrong once we looked at the dynamic behaviours.
  11. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    pv908----there are some VERY interesting thoughts here, about 90% are so far out in left field--an accurate speed would never be figured out. If you want me to work the formulas, send me a PM.
  12. 285ferrari
    Sponsor
    Sep 11, 2004
    20,984
    MD and NE
    Robbie
    Total stations and lots of data!!!
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,881
    The twilight zone
    I understand your point, it's just not relevant unless I used a different Cf front/rear. As long as Cf is assumed constant, the weight could be all on 1 tire or distributed in any way among the 4, it all works out the same.
    The assumption I made was the fronts are locked and Cf for the sliding tire is 0.8. I also assumed that although Cf in the rear is higher because the tires are not lock. The fact that they are not locked says they have probably not reached their limit either, and 0.8 would be a fair approximation or what the effective Cf is….and make my math way, way easier
  14. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    as a matter of relativity....
    international soccer pitches and american football fields are 109m long.
    the Menkaure pyramid (smallest of the 3 pyramids of Giza) is 109 metres across on each side.
    the SS Yongala which sank in 1911 was 109 metres long.
    the world's highest swing (in nz) is 109 metres off the ground. during the swing you get to 150kph.
    109 metres is about 30-35 storeys up in an office/condo tower.
  15. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Makes you wonder how a car can skid the entire length of a soccer pitch! :) That Testrossa must have been moving at a f*cken high rate of knots alright! Almost seems unbelievable how the driver was doing in the vincinty of 200km/h(would have to be close to that), then locked the wheels up and skidded perfectly straight, without deviating for 109m!!!! How long was this street again? :D
  16. loki
    loki Guest
    Jul 25, 2005
    227
    Sorry guys, I'm I missing something. I don't see any signs of a wreck on the road. It looks more like a "burn out" to me.
  17. PAP 348
    Dec 10, 2005
    100,249
    Pap
    You must have missed post 8 where he says the Testarossa hit a stationary trailer double parked. :) But it seems that the wreck/s are gone. The Police probably would have marked it afterwards. :)
  18. loki
    loki Guest
    Jul 25, 2005
    227
  19. PAP 348
    Dec 10, 2005
    100,249
    Pap
  20. pv908
    pv908 Karting
    Oct 11, 2004
    127
    Paul V
    The car is not wrecked, luckily. Parts bill currently around $39K AUD with some more to go. The bonnet is 10 grand alone. Not sure of finished quote. Insurance is taking care of that.
    The road is probably about 900 meters long after coming out of some nice curves. Could do 100 Kmh around the curves if pushed. The road was marked out by the Police 24 hrs after the accident for some reason.
    It has been off the road for 7 weeks+ and the parts are still not in the country yet. This was a very sad engine clean after 2 years of getting the car right.
  21. PAP 348
    Dec 10, 2005
    100,249
    Pap
    Farrrrrrrkkkkkk! :eek: $39K and insurance is covering it after the Police report says there was a 109m long skid mark? I find that very hard to believe mate. Insurance company's really delve into this sort of stuff, especially since there is a Ferrari involved and the quote so far costs nearly as much as Ford XR6. :p Whats the speed limit on that street. 50km/h or 60km/h.? What the f*ck was your mate doing.......trying to break a record for speeding down that particular street? :D
  22. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    cosmetic only then? 45kph can pack some wallop, but if it was a jims mowing trailer (mate of mine is a mr clip :p ) then that might have absorbed more of the inertia than your car did. did it push the trailer far from it's original position?
    how was 45kph derived as the terminal velocity?
  23. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    insurance most likely meaning they'll chase the money from the playful party if the owner's black-and-white not at fault.
    as goober says "you fook it you fix it".
    never drive faster than you can afford to. (try not to anyhoo :p )
  24. PAP 348
    Dec 10, 2005
    100,249
    Pap
    The only problem i see here is.....that the insurance company looks at the playful party and see's that they cannot come to the party, then owner has to come to the party. Then..........with massive skid marks like that, maybe the insurance company may not come to the party for the owner of the Trossa. :D
  25. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    825
    Sydney Australia
    Anthony
    I think he means the impact velocity. He got to slow down to 45Kph before he hit.
