skiing: man my quads burn! | FerrariChat
Discussion in 'Sports' started by rob lay, Feb 23, 2011.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,992
    Southlake, TX
    Rob Lay
    Jennie and I finally bought our own nice boots. The weak link was the feet and shins. Now the weak leak seems to be the quads. As I get tired end of day or end of a run the quads just burn to the point I have to take 30 seconds. I know some of this is just normal not in shape skiing you are obviously going to get tired and quads seem to be the most used muscles.
    I'm in pretty good running shape, but that didn't seem to help my quads at all. Any advice for people that don't live on the mountain minimizing the quad burn? Does it just happen to everyone? Technique things to look at? Pace myself more through the day and trip?
    FYI we only did about 15,000 vertical feet each of 3 days. Probably could have done 20-25,000 the first day, but we were actually "pacing" ourselves the first day, but then next 2 days skiing on soreness 15,000 was our limit.
  2. ChicagoVV
    ChicagoVV Karting
    Oct 26, 2003
    118
    Chicago
    Dan Van Voorhis
    I just got back from Vail with my kids....and felt the same way. A few years ago, I purchased a product - Sport Legs (www.ProLineSportsNutrition.com) sold at various ski shops in Vail and used (endorsed?) by the US Ski Team. This works well to virtually eliminate the burning.. Check it out if you car to do so.
    Dan
  3. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,896
    #3 CornersWell, Feb 23, 2011
    There are a lot of good quad exercises that will get you most of the way there, although there's no true substitute for being on the hill. However, my rehab protocols have always incorporated Sportcords (http://www.sportcord.com/). You can get a set of these for $45 dollars, and they have plenty of exercises that will help. You can do them anywhere, and, if you like, you can easily bring them in your luggage when you travel. LOTS more exercises to do that don't involve resistance, too. In short, lots and lots of squats. If you'd like a more extensive list and descriptions, PM me.
    BTW, a part of the burning is an accelerated lactic acid buildup due to the decreased oxygen at altitude. You might consider taking something like ChlorOxygen (available at Whole Foods or health food stores), as it helps hyper-oxygenate the blood.
    CW
  4. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
    Horse Stance & Tiger Balm
  5. nthfinity
    nthfinity F1 Veteran
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    If you can't hit the slopes once per week, do a lot of leaping exercises, and kicking. It doesn't matter how much you run, your quads are going to burn. Remember how your muscles are reacting to downhill skiing is your body is stabilizing you vertically; not moving the earth beneath you.
  6. rob lay
    Dec 1, 2000
    63,992
    Southlake, TX
    Rob Lay
    since cycling and even pool kicking is more quads, don't you think those would help?
  7. CornersWell
    Nov 24, 2004
    4,896
    #7 CornersWell, Feb 23, 2011
    Cycling is good (and used frequently in the off season for training by skiers), but there simply is no substitute for feet on the snow. A lot has to do with the stabilizing muscles. Weight machines, such as smith presses, only work some of the muscles, and not others. So, in some ways, you're working the unworked muscles for the first time.
    Also, the bosu is gaining a lot of popularity. Should look at some exercises there. Again, good for stabilizers as well.
    CW
  8. nthfinity
    Mar 21, 2005
    7,467
    South East MI
    Isaac not Issac
    I would think certain Yoga positions would be beneficial too for their stabilizing work.
    So none of your existing exercises would be degenerative; but there is no pure substitute IMO.
  9. ZUL8TR
    ZUL8TR Formula 3
    Feb 12, 2008
    1,354
    Fishers, IN
    work to improve your aerobic condition and to improve your lactate threshold that trains your body to deal with higher lactic acid build up that occurs when you are operating continuously at 90% of your max heart rate. When you are skiing, your muscles are anerobic.
    Don't forget that you need to remember to cool down after a long day skiing. Make sure that one last run is a gentle one vs trying to break a land speed record. That keeps you from actually breaking a leg from being exhausted ad allows the muscles a chance to work the lactic build up out. Recovery should take an hour. Also, don't forget the water intake throughout the ski day and prior to the apres ski party. Finally, stretch.
  10. Seth
    Seth Formula 3
    Feb 8, 2004
    1,551
    Texas
    Same thing used to happen to me, getting on a ski lift would be painful, and if it didn't have a resting bar I would be dying. What I've found is that doing a stair machine along with rowing helped a LOT. This last time I went skiing I didn't have any pain. I trained for about 2 months before skiing and only did about 12 minutes on a stair machine every 2 days. No problems. I also row a lot now, but not sure how much that helped.
  11. TexasF355F1
    72,498
    Cloud-9
    Jason
    I just got back from Vail too.
    I wonder how differently skiing vs snowboarding works quads.
    My quads didn't really bother me....which is surprising, b/c I suck at snowboarding!:D
  12. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,638
    Los Angeles, Ca
    Vivek
    What worked best for me was doing alot of squats and dead lifts. Dead lifts good for Hamstrings and Glutes and the Spuats are good for quads. Also do box jumps with a 24 inch box. The other is lunges.
  13. Whisky
    Whisky Three Time F1 World Champ
    31,923
    In the flight path to Offutt
    The original Fernando
    I was going to suggest go up and down a step ladder, or your steps at home, or the stair-stepper at your local fitness club.
    I had the same issues about 20 years ago, that's what I did.
  14. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    Vince Vaughn's mom is my personal trainer (she also trains a few of the Bears,including Cutler and Hanie).
    She developed Sheanetics which is a really tough combo of Pilates and Yoga.
    I have no more quad problems nor injuries (dramatically improved flexibility of all the ligaments).
  15. rob lay
    Dec 1, 2000
    63,992
    Southlake, TX
    Rob Lay
    tangent, but Vince Vaughn's mom is hot! :)
  16. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    She just turned 70 and she still could kick butt of most of the guys here, in fitness.
