SL55 maintenance | FerrariChat
SL55 maintenance
Discussion in 'Other German' started by madmaxatl, Oct 1, 2008.
  1. madmaxatl
    madmaxatl Formula Junior
    Mar 22, 2007
    687
    Buckhead, Palo Alto
    Don Johnson
    Thinking about buying one as a daily driver but need to know about their repair schedule/ how often they break down.
  2. REMIX
    REMIX Two Time F1 World Champ
    These things are VERY expensive to maintain and fix. I was on the lot looking at a gorgeous black/charcoal SL500 yesterday...make sure you have an extended warranty. This is what's scaring me off buying it - I've had a bad experience with MB in the past and these cars are no picnic off warranty. The price is right, but dunno what I'm looking at in repair headaches.
    RMX
  3. Blue4reF1
    Blue4reF1 Formula 3
    Jun 12, 2007
    1,475
    Plantation, FL
    Blake Simon
    Under $750 US a year. Love mine!!
  4. shoddy360
    shoddy360 Rookie
    30
    Beverly Hills
    Rick Zimmerman
    find a dealer to do the PPI , if not find one of the best indipendent MBZ service place to check it out,
    couple of things you should look for
    -mantinnce records
    -color of fluids (coolant - green) (brake flud - clear ) (transmission fliud - red )
    -brakes are brembo 6pistion front - 4 piston rear - do not buy over the counter parts you can use after market disc and pads
    -only issue I have see on most mbz & BMW's = catalytic coverter failure / o2 sensor.
    -what it comes down to you get what you pay for - lower the miles - higher the price will be - but its called quality. look for it spend the extra $ for a clean car.
  5. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    The abc suspension will give you the most problem. Pump is around $1200, each shock is around $1000(about the same as a Range Rover) I have seen the engines with 135k miles so you shouldn't have major problems, just small ones that cost ALOT...
