sleepf fish/top gear? | FerrariChat
Discussion in 'Other Off Topic Forum' started by Seth, Dec 2, 2004.
  1. Seth
    Seth Formula 3
    Feb 8, 2004
    1,551
    Texas
    does the sleepyfish have the top gear episodes anymore? if not where else can i get them...
    sorry if this has already been asked
  2. Turb0flat4
    Turb0flat4 Formula 3
    Mar 7, 2004
    1,244
    Singapore
    RND
  3. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    D/l rates are almost non-existant, have anywhere else to d/l from?
    Sunny
  4. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
  5. Turb0flat4
    Mar 7, 2004
    1,244
    Singapore
    RND
    #5 Turb0flat4, Dec 3, 2004
    Assuming you have broadband, I think your Bit Torrent application is not properly setup. You need to forward the relevant ports through your firewall (if you have a router or NAT firewall) and limit your upload bandwidth to a good compromise number. If you need directions, post and I can try to help.
    EDIT : I've attached a screen capture of a typical rate I get on a fast torrent (The 5th and Top Gear torrents may be slightly slower but are still OK). As you can see the d/l rate is around 180 kbyte/sec, which is very close to my connection limit. Before I set up my application, I wasn't seeing anywhere close to these rates. :)
  6. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    Please tell us how you did that!!!!! I'd love to see 180k on BitTorrent!!
  7. Turb0flat4
    Mar 7, 2004
    1,244
    Singapore
    RND
    No problem, but I'll have to post the details later today. I'm heading out (actually for a track event/high performance driving course ;) ) so I'll be a while. But I'll certainly come back and make the time to post. :)
  8. Turb0flat4
    Mar 7, 2004
    1,244
    Singapore
    RND
    Hey, I'm back ;) Pretty nice day at the track, but very tiring.
    I found a FAQ that explains it very nicely. Here are the addresses :
    http://dessent.net/btfaq/#ports
    http://dessent.net/btfaq/#speed
    Those should do the trick nicely. Main thing is to forward the ports for incoming connections (the range is 6881-6999) and to limit the upload rate to around 70 to 80 % of your connection cap. These limits can be set with the newer bit torrent clients like ABC ("Yet Another Bit Torrent Client"). The port forwarding method depends on your router, for my Linksys router, I access settings through the browser. Oh, and don't forget to set iup your software firewall to also allow incoming connections through those ports. :)
  9. bubba
    bubba Formula 3
    May 8, 2002
    1,025
    Hong Kong
    PPPP
    I get my Top Gear vids from www.racingflix.com. It's a paid site, but I get over 200KB/sec download speeds, so no complaints. This speed is straight downloading within the browser, not thru those download accelerators.
