News
Sliding Carpet on 328 - how to prevent?
Discussion in '308/328' started by LuigiVampa, May 2, 2020.
  1. lopena
    lopena Formula Junior
    471
    So I guess back in Maranello, Lorenzo, the carpet-snap-installer, only worked two or three days a week.
    Alan
    N.J.
  3. Saabguy
    Saabguy Formula 3
    1,601
    Shreveport, LA
    Always the case. ;-)
    Lester
  4. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,075
    Southeast USA
    Mike Charness
    Here's what I did... I bought a grommet kit. Then a small piece of thin speaker wire attached to a split ring at one end, passed through the grommet, then wrapped around the 6mm allen bolt. Seems to work great and is hardly noticeable.
  5. Saabguy
    Saabguy Formula 3
    1,601
    Shreveport, LA
    Let me finish the investigation, Do you now, or did you ever have factory installed clips, snaps, or other carpet retention devices?
    "And remember, this is for posterity, so be honest."
    Lester
    n
  6. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,075
    Southeast USA
    Mike Charness
    No, they did not. Though these are replacements in the car now that you see in the photo, the car did have the original floor mats in it when I bought it 30 years ago. This is a USA model 1984 308QV..
  8. Portofino
    Portofino Karting
    Sep 17, 2011
    228
    Yorkshire UK / Switzerland/ Cote d Azur
    Portofino
    Original carpets in mine have press studs to the floor .Theses sill work in stopping them slipping .
    It’s the protective over mat that has a propensity to slip forwards and jam the peddle open .
  9. trs666
    trs666 Karting
    Apr 17, 2014
    82
    Göteborg, Sweden
    Tommi S.
    I picked up 4 hooks and some grommets from a shop type home depot. Drilled the hole for 8.5mm:s. Mounted under the rails.
    ///TRS
