Slight coolant drip 355 | Page 2 | FerrariChat
Discussion in '348/355' started by lotusk, Jan 22, 2016.
  1. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    I wonder if by chance you have corrosion on the nipple?
    If you do doesn't matter what hose you have.
  2. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Nipple corrosion?
    What???
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I can't speak of .....corroded nipples.... but why not use what many oem use....a spring hose clamp.
    I have these on the bmw, seen them on many american, german and japanese products....& they spread the clamping load evenly and seal very well.
  4. tbakowsky
    Sep 18, 2002
    20,038
    The Cold North
    Tom
    Replace the hose and be done with it already.
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    or contact dave helms and get a replacement if there is something wrong with the original hose.
    there must be a warranty of some kind.
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    When I got my car I had a slight coolant leak. On taking it to a tech day they found that the hose was not fully on the fitting and the clamp was not on the hose and fitting properly.
    Can you see the offending fitting? The tech had to lay on the engine to get to it and was about to remove the engine cover but didn't have to.
    Did you do a pressure test to be sure it's from the area you think it's from? If not I would suggest that.
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanks for all suggestions
  8. WATSON
    23,926
    WI
    Having gone through an engine out for the second time, I agree with this.
    Just cut the bloody things off during the engine removal and put a decent set on that will last you 5 - 6 years.
    Yelcab: What hose do you use form the underside of the overflow tank to the engine? I trimmed the SRI hose for the fourth time but it still kinks as I put the tank bank in.
  9. fatbillybob
    Aug 10, 2002
    29,263
    socal
    SRI hose is pretty flawless. Call Dave and tell him the problem. I am sure he has a fix. I have never heard of this problem before with SRI hose. You pay a fortune for it to be perfect and it always is. Something funny going on??
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Easy fix. Get rid of the silicon hose. Surprised in 2 pages this has only been sort of suggested once. Why the insistence of "fixing" a problem that don't exist in the first place, only to create a new problem? :)
  11. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    Have any of you priced out every single Ferrari hose say from Ricambi and then compared prices to the Silicone?
    I know most could probably be cut out of rubber hose bought at your local parts store but a few can't.
    I can't believe what the Fcar tax is on these pieces of rubber.
  12. Rifledriver
    37,288
    Instead of tightening the clamp over and over get the hose off and see why it leaks. There is zero inherent problem with the hose and requires no special clamping procedure. Whatever the reason for the leak it would be there no matter the hose type.
    I have installed SRI hose in that location and never had a kinking problem. If it kinks it is cut the wrong length. Again a problem that would happen with any type of hose.
    Like SRI hoses or not, I really don't care but I have installed quite a few and have encountered zero installation problems related to the hose.
    People come here asking why they cant get air in their tire. I guess it should come as no surprise some cannot install a hose either.
  13. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Ok Brian
    Calm down
    I'm a dance teacher....why would I know the ins and outs of hose fitting to an upside down can?
    Just like you don't know the triad step in set to samba
  14. Rifledriver
    37,288
    Calm down what? I just said to take it off and have a look. You are getting a lot of stupid comments and bad advice. Just take it off and look.
  15. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Ok
    Makes sense
    Will do
  16. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    I have a question that I'm afraid to ask for fear of the answer.
    Can the rubber heater return hose (#18 from plate 20 "Cooling System Nourice"....Ferrari calls this a "return sleeve from underfloor pipe to tank") be replaced with the engine in the car? This is the smaller hose that connects to the bottom of the overflow tank at the RH front side. I know it can be removed from the tank but the question is can it be disconnected from the heater's metal return pipe? Is there access somehow with the engine in the car? I'm guessing this connection is located somewhere in front of the engine but don't know where. Has anyone ever done this or is this connection only possible when the engine is out?
    If only when out, since its just the heater return, I've thought about just clamping it off for now. Would that do any harm?
  17. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    As ever, RD comes up with the simple, pure reply to the problem - we profit, es ever, that he has seen these problems dozens of times. Listen and Learn
  18. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Not that "simple" friend
    To remove that hose is gonna be a back breaker for me
  19. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Have you checked to see that the nipple on the tank isn't deformed? Ovaled, small dent, ect.
  20. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Not yet john
    I haven't taken the hose off yet
    Need to empty the tank first
    Need a big syringe to do that
  21. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Check with wife. Maybe you can sneak her turkey baster out of the kitchen. :)
  22. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    My wife can't cook
    There is no baster
  23. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    turkey baster is what I have in my tool box.
  24. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I would use a plastic aquarium siphon hose (similar siphon also sold at most automotive stores...costs $3.00)..... you can pump the fluid from the tank to check your hose and tank fitting.
  25. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    or buy a turkey baster from the local general store.
