Slight fuel leak, very pressurized tank | FerrariChat
Discussion in '348/355' started by Nader, May 21, 2017.
  1. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    I have a slight fuel leak I haven't had the chance to identify. If the car is laid up for a few weeks, there will be a small puddle under it. Doesn't happen all the time, seems intermittent. I'm currently at a quarter tank. I just brought the car down from its upper position on the lift because our weather is finally nice, and went to fill up the tank today. After a several minute warm-up and several mile drive to the gas station, I took off the cap and there was an unexpectedly loud whoosh of air outward from the filler neck.
    I'm suspecting the pressurized tank, if overpressurized, may be contributing to the leak. What do I look for (besides inspecting the tank for holes/cracks) in diagnosing it? Thanks.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Anti-rollover valve, and/or the charcoal canister purge valves.
    As for leaks, I would remove the undertray and have a look to see if the tank is leaking. The spot welds, which hold the internal baffles in place, are know to pull out.
  3. Nader
    Feb 12, 2011
    990
    East of Seattle
    Thanks, Ernie! I've read your posts, including the beautifully detailed engine-out service. You are a credit to this site!
    ernie likes this.
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Sorry to here
    Whatever you do find it before driving it
    Fuel leaks can be very deceptive and go wrong really fast.
  5. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    One more thing Nader.
    You will want to have a look at the fuel block on the front of the engine. If memory serves me correct there was an update as the fittings could crack and cause a leak/fire.
  6. Nader
    Feb 12, 2011
    990
    East of Seattle
  7. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Give us an update after you solved the issue.
  8. Nader
    Feb 12, 2011
    990
    East of Seattle
    Partial update:
    I read not only Ernie's anti-rollover valve thread, but also his imploding gas tank thread. I feel like I'm mildly educated in Ferrari 348 tank fume management.
    I don't have a lot of time to fully investigate this pressurized tank issue of mine (I'm obsessing over a slow restoration of an FJ40), but I did pop the engine lid and had a look. I pulled the line off the bottom of the anti-rollover valve, and heard a couple tinkles of what sounded like pebbles falling out of the hose. Are you thinking what I'm thinking?
    I connected a separate clear hose to the nipple as a straw, and was able to blow through it with some pressure and get a quiet cazoo noise. I wonder if this valve was plugged? Surely, the amount of pressure I noticed at last fill-up should have activated the cazoo. Should you be able to blow through the bottom (tank side) of the valve easily?
  9. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    There is a steel ball inside the rollover valve. My guess is over the years the gasoline vapors cause the ball to developed a varnish on it. As a result is gets gummed up, and thus gets stuck and cannot operate to allow the pressure from the fuel tank past it, and into the charcoal canister.
    The "kazoo" sound comes from the air passing around the ball, causing it to vibrate inside the valve.
    If the car were to roll over, the ball is supposed to close the opening, and thus prevent fuel from leaking out the little tubes.
  10. mclaudio
    mclaudio Formula 3
    Dec 13, 2003
    1,272
    Seattle area
    Claudio
    #10 mclaudio, May 24, 2017
    Does anyone have any suggestions on where to buy this rollover valve? Other than dealership, I checked on eBay and Ricambi, but they're either unavailable or they only have for other models (doesn't look the same as what is originally there). Otherwise, I may have to try other rollover valves designated for other models. Thanks.
  11. Nader
    Feb 12, 2011
    990
    East of Seattle
    #11 Nader, Aug 29, 2017
    OK, I have an update and a solution for this thread. I continued having issues with tank pressurization as the fuel in the tank got hot from driving. I had to leave the fuel cap loose to relieve the pressure until I came up with a permanent solution.
    A replacement rollover valve is unavailable. I cruised eBay, and found one from Chrysler that also fits the DeLorean. Only $25. Look to be about the right size. I ordered it, and it came with a bunch of DeLorean literature packed with it. Kind of funny.
    I trimmed it up, but looking back, I probably should've left one of the existing plastic mounting tabs as it would've likely fit on the existing 6mm mounting stud. Anyway, I used a bit of rubber to shim it up, and used the original mounting clamp. Because the nipples are in opposite directions, I had to use a longer replacement hose going from the valve to the carbon canister. All I had on hand was that grey poly tubing for my motorcycles. I'll get the correct cloth-braided fuel hose tomorrow. I was able to do all of this from above, I did not remove the wheel and liner, though it would've provided better or easier access.
    Anyway, it's all buttoned up, went for a good drive, and there was no whoosh from the gas tank when I unscrewed the gas cap, and no fuel leaks. Fingers crossed. Soooo, does this make me a stooge?
    ernie likes this.
  12. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Excellent!!!!
    Stooge indeed, especially with your solution. Speaking of, what is the part number for the Chrysler/DeLorean Rollover valve?
  13. Nader
    Feb 12, 2011
    990
    East of Seattle
    Thank! Part number on eBay is 4002012, using the search modifier "rollover valve." Looking that up, the most common hits are Jeep CJ, Chrysler, and of course DeLorean. If you're shopping directly from the DeLorean parts site (DMC) the number is 101402.
    This is just a ball valve with the correct sized nipples and almost correct dimensions to fit in the original clamp ( after some Dremel work). Summit racing also sells a fuel check valve that would probably work if you attached a couple of adapter barbs, and zip tied it right side up. Would probably work fine, though look less correct.
    ernie likes this.
  14. Nader
    Feb 12, 2011
    990
    East of Seattle
    The difference between the two valves, is that a take some force to blow through the lower hose on the original valve, and then I get that faint kazoo. With some attempts, it remains completely obstructed. I think that's how my tank gets pressurized. This all happens even though you can hear the ball rattling around inside.
    The new DeLorean valve flows freely in and out through both hoses, without resistance, unless the valve is tipped sideways. No obstruction or kazoo. I did some more Internet searching, and found this other valve from an old diesel Mercedes, which might also work:
    https://mercedessource.com/store/search?keys=DSL-COMFTVV
    ernie likes this.
  15. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Right on, thanks for the info.
  16. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
  17. seabass23
    seabass23 Karting
    Nov 6, 2016
    156
    St Albert, Alberta
    Matt
    Wade likes this.
  18. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
