Slight fuel smell at high revs on 360 Spider | FerrariChat
Discussion in '360/430' started by JustinSpain, Jan 10, 2016.
  1. JustinSpain
    JustinSpain Karting
    May 27, 2015
    150
    Manilva, Spain
    Justin Aldridge
    Noticed past couple of days a slight smell of fuel when the engine is at high revs. Can't smell it at idle or at revs less than 6K ish.
    No CEL showing and car has half a tank of fuel so it's not over filled or anything like that.
    Anyone any ideas?
  2. anconbrat
    anconbrat Karting
    Jul 9, 2011
    96
    East central Florida
    Don Morton
    Justin...a fuel smell is something that needs attention (now). First place I would look into
    are the two fuel pumps. From my experience.
  3. JustinSpain
    JustinSpain Karting
    May 27, 2015
    150
    Manilva, Spain
    Justin Aldridge
    Thanks. I will have it looked at this week and post here the findings.
  4. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    Is it at any time, or soon after a fill up?
  5. JustinSpain
    JustinSpain Karting
    May 27, 2015
    150
    Manilva, Spain
    Justin Aldridge
    I last filled up probably a week ago but it's only been happening over the past couple of days.
  6. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    +1 almost always the crappy plastic top on the fuel pump assembly- use search- you will find a bunch of DIY with pictures in the event u wish to do it yourself. Easy job but takes some time. Those plastic tops on the pumps have 7-10 year lifespan before they get brittle and leak if they break u'll wish you had a large fire extinguisher. Don't run your car until you've inspected them.
  7. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    I had an off and on gas smell, turned out to be the gasket under one of the evap hoses at the top of the tank. I replaced all 4 and no smell.
  8. 24000rpm
    24000rpm F1 Rookie
    if I were you , I won't drive it until I found the fuel leak somewhere. It gotta be somewhere unless your senses are cheating
  9. Chrisnlbc
    Chrisnlbc Formula Junior
    Jan 9, 2015
    374
    Huntington Beach
    I agree with the fuel pumps. Mine did the same exact thing. Replaced both.
    Chris
  10. Dano360NC
    Dano360NC Karting
    Aug 11, 2012
    167
    Southeastern PA
    Dan
    Plastic on top of the fuel pump.
  11. delaney
    delaney Formula Junior
    Nov 8, 2003
    720
    Montgomery TX
    PETER DELANEY
    Not sure pumps would give the smell only at high revs. Mine smelled as soon as the fuel system charged.
  12. jackgt
    Jan 27, 2015
    574
    california
    Jack
    can you get just the plastic screw on tops? If not it would be a good project for someone as I would replace mine just for maintenance.
  13. JustinSpain
    JustinSpain Karting
    May 27, 2015
    150
    Manilva, Spain
    Justin Aldridge
    I'm taking it to the mechanic on Thursday so I'll post what he says on here!
  14. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    627
    Eden Prairie, MN
    Matt
    Great, someone, someday will do a search with your symptoms and will appreciate having the answer!! Thanks for being part of the community!
  15. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    I have the same issue. Only happens when the tank is newly filled up to halfway used.
    It smells on high revs but when the tank is less than half you don't smell anything.
    Ideas?
  16. delaney
    Nov 8, 2003
    720
    Montgomery TX
    PETER DELANEY
    Have a smoke test done. That will establish where any leaks are.
  17. JustinSpain
    JustinSpain Karting
    May 27, 2015
    150
    Manilva, Spain
    Justin Aldridge
    #17 JustinSpain, Jan 21, 2016
    Looks like they have found this issue. It's this filter in the picture here. I think it's called a fuel vapour separator....will get full details next week when they get the new filters and replace them.
  18. danny_acs
    danny_acs Karting
    Aug 17, 2015
    105
    London, UK
    Jumping in a bit late, but better than never.
    ALWAYS address these issues immediately. Last time I was in a car with a bit of a gasoline smell at high revs this horry story happened to my friend's E30 Convertible:
    [ame=http://www.youtube.com/watch?v=YLZ2mINwmRQ]BMW 325 E30 on Fire - YouTube[/ame]
    One of the fuel lines was loosened during the last inspection. After a "spirited" morning carpool drive to work, some fuel dripped on the hot exhaust headers and the hood padding/insulation caught on fire. No one carries a fire extinguisher here in the UK, and even though it took 7 mins for the fire truck to arrive, the car was totalled...
