Slight miss / not running perfect | FerrariChat
Discussion in 'Technical Q&A' started by GTHill, Aug 17, 2007.
  1. GTHill
    GTHill F1 World Champ Lifetime Rossa Owner
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    It is hard to explain, but my car (328) isn't smooth at all RPM's.
    At a steady RPM, like 3500, it will run fine, but will miss about every 20 (total guess) power strokes. It accelerates fine but it is annoying.
    I have new spark plugs and wires. I did a resistance check on all of them from the inside of the distributor to the end of the extensions and it looks good.
    The contacts on the rotor and the rotor itself are worn so that may be an issue, but an expensive fix.
    Could more powerful coils help at all? I have seen a few threads on it but haven't seen any actual tests.
    Any help would be much appreciated. Thanks!
    Gene
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,931
    (Assuming that you have a US version 328) One thing you might try (just to better rule out the fuel side of things) is to unplug the O2 sensor and see if the behavior is the same or different (i.e., when the Lambda stuff is running at a fixed setting).
  3. GTHill
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Does that unplug from the sensor side or elsewhere? Thanks!
    Gene
  4. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    You may have a spark plug extender going bad. Pull them out and check very carefully. Alternatively, buy a new one and exchange it with one cylinder at a time. Cheap way to find a bad one.
    Dave
  5. GTHill
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Wouldn't performing a resistance check discover that problem?
    Gene
  6. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    They _should_ be zero ohms, but no matter what, they should all be the same.
  7. Steve Magnusson
    26,931
    This thread shows a picture of a 328 where the Owner found that the single wire from the O2 sensor was already disconnected -- you'd do the same for the test:
    http://ferrarichat.com/forum/showthread.php?t=153484
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,348
    Could be something as simple as a plug extender not properly seated on the plug. I found a couple of mine were a bit loose & that seems to have cured a similar problem - just required a little fettling of the spring thing inside the extender.
    Also, as has been said, check all your extenders for scorch marks & cracks.
    You can get the pattern dizzy caps from Superperformance & these seem to work well by all accounts.
    Another option is it could be the crank sensor is starting to go south - do a search for that & how to test them.
    Getting into the land of the "horribly expensive" then you are looking at the coil(s) and/or the ECU starting to break down.
    I.
  9. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    Not necessarily---they are NOTORIOUS for shorting out to the head---examine them all with magnifying glass on inside and see if htere is any burn indication. sometimes a small hole will be on outside with a black scorch mark at it...replace them all and for added protection i wrap mine with about 3 layers of electric tape or 1 good shrink-wrap coating.....
    I have had a dozen or more people call me with 308's misspireing and 90% of the time it is the extenders....
