Slight vibration in my 05 QP, Help! | FerrariChat
Discussion in 'Maserati' started by S-T48, Sep 13, 2009.
  1. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    #1 S-T48, Sep 13, 2009
    Guys, I need your expert advice on this. Whether the car is in first gear or in neutral, at around 1700 to 2000 Rpm, I feel some engine vibration. First I thought it was the gear box, but then, I realized I could duplicate the same vibration while the car is in neutral. As I said, I only feel the vibration within that rmp range, anything over or under is fine. It feels as if one of the pullys is not ballanced and it translates the vibration into the cabin. BTW, I Have only had the car for two weeks, could this be normal????
  2. technician F
    technician F Karting
    Sep 15, 2009
    57
    Maybe damage of engine mounting,it is common in QP.
  3. Pitpass
    Pitpass Karting
    Apr 2, 2009
    77
    Motor mounts may need to be replaced. Maserati updated/upgraded the mounts in a campaign a few years back. Heat shields are also added to help protect the mounts. If they haven't already been replaced once then it should be covered by Maserati.
  4. S-T48
    575
    Stevenson Ranch, CA
    Thank you guys sooooo much. I also think it is the motor mounts since the car has 47,000 miles and probably has the original motor mounts.
    I'm glead to be part of this community
