355 - Slightly thicker oil for summer? | FerrariChat
355 Slightly thicker oil for summer?
Discussion in '348/355' started by SA Mike, Apr 20, 2020.
  1. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thinking about going to slightly thicker oil (10-40) for the the summer since I’m here in Texas and temps get over a 100. Will that help the oil from thinning out so much and also help in a hotter climate.
  2. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    Going from a 5-40 to 10-40 makes absolutely no difference for hotter climates. This subject has been beaten to death. Use the search option.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  4. m.stojanovic
    m.stojanovic F1 Rookie
    3,242
    Serbia - Niš
    Miroljub Stojanovic
    It appears that 5-40 actually has higher hot (100C) viscosity than 10-40. I looked at a few datasheets of different oil brands and found that at 100C 5-40 has viscosity between 14 and 15 whereas 10-40 has between 13 and 14
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,239
    CT
    John Kreskovsky
    It really depends on the oil type and brand. Hers are the Pennzoil specs for 0w40 and 5w40. Note the 10w40 is Amsoil motor oil. But note that even 0w40 has higher viscosity at 40*C than any of the oils at 100*C. Ther eis really no reason you could not run 0w40 in most climates.
  6. NoSpeedLimit
    NoSpeedLimit Karting
    Sep 6, 2013
    185
    SAE J300 defines that a 40 oil can have a kinematic viscosity between 12.5 and 16.3 cSt.
    So for me the AMSOIL XL for me is a little on the high side. A 50 oil starts at 16.3 cSt.
    http://www.lube-media.com/wp-content/uploads/Viscosity-matters-WEB-ONLY-Sept19c_FINAL.pdf
    The viscosity index of above 180 tells me that this is a synthetic oil. Meaning that not so much viscosity improvers have to be added.
    They can degrade with time.
    The other two a standard mineral oils.
  7. m.stojanovic
    3,242
    Serbia - Niš
    Miroljub Stojanovic
    Just reminded me that I have a number of documents on Amsoil engine oils. I have found that Amsoil 10w-40 Premium Protection oil is probably a very good choice for the 348/355. Not only its viscosity but, more importantly, it has a very good ZDDP content (hard to find these days).
  8. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    399
    instead of looking your local weather, you need to look at your engine oil temp.
    My Scud takes forever to get to 190F with normal 15 min driving.
    My GT350R will hit 240F just idling (for 30 minutes), just did that today.
    if you track a car, some car will never top 250F, some cars will hit 295F all day long even with an oil cooler. some will be over 300F stock, you really need 10w-60 then.
  9. johnk...
    Jun 11, 2004
    11,239
    CT
    John Kreskovsky
    Here is the latest from the Amsoil web for their XL oils for gasoline powered vehicles. The AMO are really meant for diesel applications, but can be used in gas powered as well.
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Amsoil has a zrod oil with high zddp. Also redline as well. Both have more then most oils.
  11. johnk...
    Jun 11, 2004
    11,239
    CT
    John Kreskovsky
    It's not really needed because most people don't put that many miles on between oil changes. According to a research paper I read on flat tappet wear (thought I had it saved somewhere but can't find it) higher Zddp doesn't protect better, just longer because the zddp breaks down over time and usage.
  12. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    What is specific reason that ZDDP would be of benefit with F355 engine?
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  14. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Politics, religion and oil type discussions always bring a crowd. Its like Walmart, no one ever admits going there but you always see everyone there!
  15. ttforcefed
    ttforcefed F1 World Champ
    19,257
    just use 0w40 all year round
  16. johnk...
    Jun 11, 2004
    11,239
    CT
    John Kreskovsky
