355 - Slime...in electrical connections? | FerrariChat
355 Slime...in electrical connections?
Discussion in '348/355' started by MrJames, Aug 19, 2022.
  1. MrJames
    MrJames Karting
    Apr 12, 2020
    62
    South Florida
    James Webb
    I get how my brake lines could have gunk in them, whether it's degradation of fluid caused by heat/time, water adsorption from the atmosphere, contamination by adding something to the DOT 4, or some combination.
    But my MAF connector shouldn't have had any liquids in it in the first place, right? Obviously I was able to clean it, but any clues on what happened here? (I had to take it off to get clearance to access to the bypass tube to install a new thermocouple.)
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Possibly dielectric grease grease to protect it from corrosion, salt and water etc that got old.
    MrJames and Mike Morrissey like this.
  3. MrJames
    MrJames Karting
    Apr 12, 2020
    62
    South Florida
    James Webb
    Ah, good point. There is no salt here (unless you drive to the beach) so I tend to forget about it.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Probably there is water however and that corrodes as well. Even washing it. Good luck!
